There have been a few threads on the forum, more specifically in the 3IS subforum, but I want to clear up this issue for good. On my old 3IS, I had bought a smart Card key for my IS. Even though the website said it's ID and my car's VIN were incompatible, as well as the key fob and card FCC ID's being different, my dealer was able to program the key no problem. I still have that key, and went in to my local dealer to have the key reprogrammed for my RC. Now if im not mistaken there have been a few other members who have had no issues programming this key. For reference, my RC's FOB ID's are as follows: FCC- (HYQ14FBA), and IC- (1551A-14FBA). My card key, that worked on my IS, ID's are: FCC- (HYQ14CBB), and IC- (1551A-14CBB).
I brought my keys into the dealer to have them program the card while my 35k service was being done, and came back to a service report saying that the key was unable to be programmed because of vin incompatibility. I came back into the dealer a few weeks later to see if they could try programming it anyways, as some other members have done the same thing with success. My rep told me that they did actually try to program it, although to no success. Should I visit a different toyota or lexus dealer to have it programmed? Has anyone with an RC experienced this? Should I try to go to an independent key programmer to have it done?
Now I could be wrong...but
I have heard that the current generation Lexus smart keys can only be programmed once at the dealer. They won't/can't program a previously programmed key or key card.
Now I have heard independent shops can reprogram previously programmed 1st gen Lexus smart keys (not counting the LS 430 as 1st gen), but I just haven't heard of them reprogramming the current 2nd gen.
When you bought the key card for your IS did you buy it new?
Yes, I bought the key brand new, from the dealer actually. Service guy got me a deal on it with install. I guess ill go calling key shops locally and see what they can do.
Pittsy, I just bought my 2015 RC and it only had one key fob.... I found one exactly like my original one at...https://www.keylessentryremotefob.co...exus-rc350.htm ... It was only $85.00 shipped.
And then I made sure the inside Chip board had the same numbers as my original fob....which it did. The I found out that some "Ace Hardware" stores can program your key fob for *** little as $50 bucks! SO I found one near me that would do it....even tho i had my own Key Fob. Make sure you tell them that you have your own Fob.... They usually want to sell you their own. But I got a cool guy that said he would do my car. HE only charged me like $18....So I gave him like $30 bucks for a tip!
So I basically got my Key Fob for about $130. Hopefully you can find a vendor to program it cheap. But I called a Locksmith and they were a minimum of $165 if you had your own.
My suggestion is that you buy it new and Lexus should be able to program it. I've shared more details on my buiild thread about not being able to get the physical key cut by Lexus but programming was never an issue. Additionally, you should keep in mind that the batteries for these keys are hard to come by (Only a few sources online and they always have problems with not having full charge from my experience so far.) That said, I'm picking up a replacement battery from the dealer today and hope I have better luck.
Hey!
I actually solved this a while ago, shouldve updated here...
But, what I did is bought a new card key, and bought a 2 day service techstream subscription and programmed the key myself. Been using that and that key only for months now, no problems!
Thanks again
Sorry, new here. Have you tried programming it yourself. Techstream is really cheap online.
What I wanted to ask was, do you mind sharing the back info on the Smart key for your 3IS. I wanted to get one and I think Im suppose to get the HYQ14CBB version for my '14 is250. Thank you
**Edit** Sorry. I got confused with all the numbers where you already wrote what was on the back of your RC and IS. You assured me I'm going to buy the right one now. Thanks!
Reason: revision
