Front Axle Hub Removal
Old 02-01-19, 07:53 AM
JRC350F
JRC350F's Avatar
Question Front Axle Hub Removal
Hi. I am performing the Lexus bulletin L-SB-0100-16 (Attached) to replace the front 2-piece rotor with the 1-piece rotor. The SB calls for installing a shim between the front knuckle and wheel hub. Can anyone help me out and provide the Drivetrain - Axle and Differential - "Axle and Differential: Front Axle Hub: Removal" page of the 2015 RC 350 repair manual? Thank you in advance!
File Type: pdf
Old 02-01-19, 01:54 PM
jonmonkey
jonmonkey's Avatar
What are you replacing it with? I swapped out my stock 2-piece rotors for a 1 piece Power Stop set and simply removed the wheel, caliper and rotor...then replaced in reverse order. No issues ~10,000 miles later.
boss22
12-22-20 04:30 PM
TMaxxTim
08-18-18 11:07 PM
InfamousLS
09-27-13 06:17 PM
tyncobb
01-09-10 03:12 PM
picomode
RX - 1st Gen (1999-2003)
03-30-09 05:19 PM
Quick Reply: Front Axle Hub Removal
