Blackvue Battery Hard Wire
Hi all,
Recently just purchased an RC350 F sports 2019. Just wondering does anyone know which fuse under the glove box is the best to tap into to hardwire a blackvue battery?
I know it has to be 20A or greater but not sure which is the best
Also anyone know what the fuse type is called?
[QUOTE=jhs82;10569864]Use a fuse tap like this one. Then you won't put any load on the current 15A fuse, and can put a seperate 20A fuse for the Blackvue battery.
OHHHHHHH makes so much sense now. So it won't overload the circuit if it's drawing 20A from that circuit?
[QUOTE=tronder;10569866]Exactly. With this you'll create a seperate circuit (from a shared source) with its seperate fuse. No extra load will be added to the original 15A fuse.
Either way, if you have a Power Magic Pro, you can tape into any fuse that is constant and any that turns on with the ignition. Personally for my RC, since I had to remove the fuse box cover and keep the fuses and taps exposed, I went with an OBD2 power supply for my BlackVue.
RyGuy0062
11-09-17 09:38 PM
