2015 RC350 - Fuel Gauge Not Working
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
Hello all, I did a quick introductory search and couldn't find anything on this site, let alone the hours searching on google for this issue. The car has about 70k miles on it and the fuel gauge stopped working.
Oddly enough it didn't just BREAK. One day when the car had about 30 miles range remaining we filled it up and started driving. When I drove to work the next day I realized it said 20 miles left, which didn't make sense so I stopped and tried to fill up thinking maybe a crazy leak or something and it only took a few dollars of fuel. Eventually it said 0 miles remaining and continued to drive. So the gauge wasn't working, which sucked but okay I'll figure it out.
Nothing on google so I took it to my local shop and they had it for 2 weeks and ripped everything out and tested everything and said they couldn't find anything wrong and that I would have to take it to lexus. Thankfully they didn't charge me anything; but lexus was privy to just replacing the whole thing and the part was $1,700 alone (or so they said). I realized there is currently a recall on fuel pumps on RC's but lexus USA said my car isn't on that recall and my description sounds unlike the issue.
Anyone have any ideas? Preliminary testing tomorrow will consist of attaching a ODB2 reader and seeing if that can get the fuel gauge levels to potentially narrow down the issue to the driver cluster?
What part is Lexus wanting to replace for $1700?
They told me they wanted to replace the whole fuel pump assembly.
Edit: They didn't even look at it, that was just an introductory phone call.
I think Toyota/Lexus expanded their recalls for the fuel pump issue. Check the below article.
https://www.autoblog.com/buy/2015-Lexus-RC+350/recalls/
May not be that credible but try searching online for more recall information about your vehicle.
I'd just bring it to Lexus again and tell them you are experiencing pump related issues (search online for the common pump issue symptoms). Worth a shot IMO.
@s3v3n - I appreciate it. I've googled all over - I also reached out to them in regards to the recent expansion and my vehicle is still not in the recall. Super frustrating.
Work things came up so I haven't been able to test the reader via OBD2 yet but I will report once done.
Is the fuel gage working properly? Or is it on still E after you fill up? Just trying to understand if it's the fuel gage broken or if the "fuel left" mileage is incorrect.
https://imgur.com/a/h59R6dy
It is not only showing the gauge at E but also telling me I need to refuel in the cluster.
I couldn't get any info from torque regarding any error codes OR any info about the actual fuel levels BUT I downloaded some random car scanner and it took ~5 minutes to scan and I received these 2 codes.
B1500 - Dashboard/Instrument Cluster #1
AND
C1AB6 - Blind Spot Monitor (probably unrelated)
edit1: going to continue my google search with this new info for B1500
Since the car still runs normally, it's safe to say the fuel pump is fine. The B1500 code is saying there's a problem with the fuel level sensor, which makes sense with what you're experiencing.
https://www.autocodes.com/b1500_toyota.html
Replacing the sensor is not difficult but you will need to pull the whole fuel pump assembly out.
So quick question. Would you recommend Lexus OEM for this or grabbing something from autozone/advanced Auto? If it is Lexus OEM is there a specific website that works or should I just hit up the local dealer? Thank you for your help, I know those are basic questions but I know some OEMs that have worse quality then aftermarket and I'm not privy to Lexus yet.
I haven't been able to get the replacement part as I've been super busy with work. Otherwise I'll update once anything has been worked on..
user 732028210
15
11-19-20 07:52 AM
