Custom performance settings
10th Gear
Alright RC crowd. Saturday night question. Have any of you adjusted your performance settings under the custom setting? If so, what and does it remember when you turn the car off and on again, basically does it stay in the prescribed setting? thanks!
If you mean custom mode (push the button when in standard)...It will revert to standard if you shut the car off, but if you push custom again, it will go to your preselections. You don't get a lot of choices nor a lot of explanation in the manual as to what is actually happening. I think, based on other discussions that the Powertrain selections of Eco, Normal and Sport is just the throttle mapping and I don't think it adjusts the transmission settings at all.
Chassis selections are just Normal or Sport. Don't know how firm Sport is.
Air Conditioning is just Eco or Normal which is useful if you want normal AC when driving in Eco.
Elsewhere you can also customize the instruments to look more like you want when in custom since you can choose a Custom Mode look that is similar to ECO.
Since I am trying not to jackrabbit in these days of $6 gal gas, I have custom selected powertrain to ECO mode and Normal AC with Normal Chassis and I use the ECO instruments. Each time you select Custom, you can change the selections using the trackpad.
RA40
CL of Southern California
10-24-19 08:00 PM
