2020 RC 350 TPMS Sensor Problem
Hello - I bought my RC 350 used and when driving home from another state, a TPMS warning came on - not the normal low PSI but a "system malfunction" warning. I figured it would be covered under warranty, so I went to the dealership. They said aftermarket sensors were installed, so $800 to replace.
So, I got the Carista app and programmed all the sensors into the car - still same problem.
I took it to discount tire instead. The removed the ones in there. Two tires had PMV-E000 sensors, and two tires had PMV-C010 sensors. They installed 4 new sensors, gave me the ID's, and I programmed them in with Carista. Still didn't work - no more TPMS failure, but the PSI does not show on the dash.
Then, they said they put two of the wrong ones in, put new ones in, and told me I shouldn't need to program anything, just drive. I did that, and still - no PSI on the dash.
Does anyone know what the right part numbers are in the RC 350? I found this web page with a couple options, but they all say "OEM Part Number Check Required from dealer" for the 2020 RC 350. Not for the years before or the years after.
https://www.tpms.com/2020-Lexus-2020...PMS-s/9941.htm
This is driving me bonkers. Anyone have any ideas? I know it is not a huge deal to have TPMS not working as long as the light is not on the dash - I can check my pressure manually. But, I want my RC 100% functional.
Tom
Tom
pearsth (05-21-22)
I find it very odd for a 2020 model having a non-oem tpms, unless the car came with aftermarket wheels then that is a different story.
Anyways, LexusPartsNow has this in stock.
https://www.lexuspartsnow.com/parts/...tra2=&filter=()
Amazon also has it for a lower price
I bought 4 of these for my 17RC's second set and they are working great. No issues whatsoever. I suggest just buy them, come back to discount tire and have them replace it again.
Funny coz the 2008 IS350 has two slots.
And it also sounds like the TPMS sensors I put in my aftermarket wheels for the NX will not work on the RC either. They are P/N - 42607-30100.
At $60 a pop I may just leave those sensors in and not worry about the TPMS for the summer wheels on the RC.
Thank you for the info!
That's what I was afraid of, I doubt it's changed on the 19.
Any luck with this or can you provide the instructions on how to program in Carista? I bought a set of Denso sensors from Rockauto for my new wheels and my local tire place is saying they need some sort of code to program them to my car. 2020 RC 350 F Sport.
The ID’s for the sensors are printed on them. If they are already installed you are going to need to find a shop with a tpms scan tool to read and program the ids to the car.
Following up on this I went to several tire shops who confirmed the car was programmed properly for the Denso sensors but they would not work. Thankfully I was able to get the original sensors back that I sold with the stock wheels and they work perfectly. Now I'm trying to get a refund from RockAuto.
ColdFusion
05-21-18 12:42 AM
