Trying to hear what the Mark Levinson can do.
10th Gear
Hi, I am a 2017 Lexus RC owner with ML system desperately trying to play HDtracks music in my car. I down loaded a 2022 Hi-Res Sampler [96kHz · 24bit] collection on HDtracks site to my MacBook M1 and the music plays on the MacBook and plays off the USB stick in the Mac but I am having no luck getting it to play in my car off the USB stick. The music is FLAC audio [96kHz · 24bit] averaging 100MB per song. Any suggestions?
Get yourself familiar to search button.
2nd post on this tread will guide you.
https://www.clublexus.com/forums/rx-...-for-mp3s.html
CharlieRC (09-25-22)
10th Gear
I am looking for a way to play lossless surround sound music in my Mark Levinson 7.1 surround sound system. Currently I have several ways to play my favourite music through the system in a stereo format but 7.1 surround sound is different?
If there is any Audiophile out there with a RC who have found a way to play lossless surround sound music or HDtracks please let me know. I'm not looking for a way to play a MP3.
The head unit of the ML is actually a PIONEER deck, to it has a pretty good DAC.
What you need to try is adjust the Equalizer and Surround Setting.
This is what I did my my ML settings
The equalizer is best set below 0db , leave surround ON (cause i think the ML DSP is tuned for that)
You should crank past 45 level to wake up the speakers
good luck
BrianRC350 (09-28-22)
10th Gear
I have had no luck trying to play FLAC tracks using USB stick on my 2017 RC. I have been told and read in the manual that the USB does not recognize FLAC, I believe in newer models it works so I'm limited to the CD/DVD option.
I agree about reading from usb sticks, I had the same problem with WAV files. Hence started using Amazon Ultra HD service from my phone
Are you able to get something other than stereo from the Amazon Ultra HD service?
I assume you are connecting iPhone to head unit via Bluetooth so the stream remains digital and the ML head unit can decode the stream and convert digital to analog.
i have a ton of 5.1/7.1 records in flac format that I could convert to DVD-V and get surround sound to play that way as I’ve seen others mention in threads.
Im just curious if you have any advice on getting surround sound working from some digital source.
IF you have a decent current mobile with a good DAC or Bluetooth Profile, you should be able to play from your phone via 3.5mm audio jack (analog transfer) or bluetooth (digital transfer). If your phone has a good internal DAC (min 24bit), then your will get higher fidelity via the 3.5mm jack.
TheForce
06-08-17 01:17 PM
