So I ended up buying an RC F stock quad exhaust to replace the stock RC 350. Ended up going pretty well and I definitely love the way it looks and sounds. Everything bolted up using stock bolts and rubber hangers. Only issue I had is using the stock rubber hangers on the muffler end because it basically pushes the top side of the tip onto the bottom of the bumper. I put all but the inside rubber hanger on the muffler but that caused the exhaust to rattle. Ended up buying a set of adjustable rubber hangers and putting the muffler on the second hole down fixed that issue so no more rattle. Really easy upgrade to do all you need is 14mm socket, 14mm wrench, and adjustable pliers, 30-45mins done. Pipe is bigger so it has a deeper tone. After it was put on. Ramps make it easy You can see the top tip pretty much touching the bumper. No longer touching when I put the adjustable rubber hanger.
Great work bro.. love the look and i didnt realize RCF stock exhaust is a direct bolt-on for us regular RCs. Please can 'you take a sound test video and also a link for the set of adjustable rubber hangers you got. thanks in advance. Cheers
That actually looks so sick compared to the stock RC 350s , honestly didn't know it was that easy since it seems to be just bolting on! Where did you buy the RCF tips from?
Actually got really lucky that someone in my area upgraded his RCF exhaust so he didn’t want to keep the stock. Scooped it for $300
I feel like the weight would be the same or heavier than stock. Looks amazing though. Love the way the quad tips look staggered like that vs these axleback/muffler delete kits I’ve seen.
RCF Exhaust's are titanium. Actually a massive weight saving moving to them.
