RCF auto cross lap
RCF auto cross lap
Same RCF at Barber Motorsports
cvt (09-30-23)
I had a 2001 Celica GTS. Had TRD strut braces, suspension, brakes, etc and weighed at only 2,650lbs @ 180hp. It was slow but if there was one thing it could do well was cone chase LOL. Glad to know as “big” as the RCF is that it can cone chase too.
Autox events were so fun and much cheaper than a full on track day. It was also a good gateway drug into that life. The only thing I hated was waiting around for your turn in 115 degree SoCal weather and have the runs only last :40-1:00. Miata’s and MR2s rules but we also saw some big boys like mustangs and Zs.
05RollaXRS (09-30-23)
cvt (09-30-23)
I know you took the RCF on auto Rolla. How did it feel for you? Any TVD settings or set up you had to prep? Stock pads?
At high speeds, TRACK mode is much better than SLALOM mode and the car behaves very differently. The response from the steering is a lot more linear in TRACK mode while SLALOM mode especially since I have installed LCA USRS bushings, have become downright scary at high speeds as even a small amount of lock will make the car can at times dart violently at high speeds left/right. TRACK mode on the other hand is much more progressive and more linear either oversteer wise if you are turning tight and pulling the nose in hard at high speeds, the tail will gently start stepping out. SLALOM mode can snap the tail on the other hand at higher speeds.
Have very little experience with NORMAL mode, but I just felt the steering was "lazy" in NORMAL mode and required more active steering angle so I never explored it much further.
ArticKnght
IS F (2008-2014)
02-03-11 09:45 AM
