Did they change the pads for the refresh models? Dealer pulled vin and came up with only one set of pads for the rcf 2022. It’s the same pads the track Edition used so not sure if the 2015/2019 pads fit the newer rcf.
Has anyone swapped pads in a newer rcf to confirm this? I want to cut down on brake dust because these stock pads are horrible for it, not sure if Tom’s mu etc will work.
No clue, I don’t see any pads that aren’t $950 for the 2022 rcf oem. Two pn and both appear to be similar at $967. I’m assuming I’d be the w240? Makes zero sense here.
