Map/Footwell Lights Not Turning On When Door Opens
Old 04-23-24 | 07:56 PM
CT3IS's Avatar
CT3IS
Default Map/Footwell Lights Not Turning On When Door Opens
Hello,
I want to start off that I already plan on checking the fuses. I just want to hear other opinions on what it could be if it isn't the fuses. Heres the problem. 2015 RCF, when I open the doors, none of the lights turn on. (and yes i tried pressing the "door" switch) I was wondering if there is anything else I should check before buying a new unit? TIA
Old 04-24-24 | 06:54 AM
arpus 7's Avatar
arpus 7
Default Inside lights not coming on.
There is a switch up in the top next to the sunroof button on the right side. Press and hold that in. Hope this helps.
tubenut96
11-04-22 09:14 AM
mikemamas
CT 200h Model (2011-2017)
01-23-22 09:31 AM
oleSLICK
04-13-17 11:16 AM
Tsmith1982
03-29-15 03:36 PM
SoCal Cyco
09-05-12 07:54 PM
