Moonroof noise
Moonroof noise
Bought the car with a very slight moonroof noise when you lift it up around 4 years ago and never thought anything of it. Hardly use it. Today I thought it has been been louder than usual. Not sure if I just need to grease or lubricate something. Only makes the sound when I open and close…it doesn’t do it when it slides back.
https://youtu.be/HcBnqQTA0z8?si=SVGf_5whXz-tAq-4
I wanted to get some takes and advice on how to resolve or diagnose this. It’s not a big issue. Again I hardly use the moonroof.
Thanks to all in this forum again for the help.
Last 2 Lexuses also had same problem. Motors were replaced as noise due to uneven opening from poor torque.
Lubing is a temporary improvement but not a fix unfortunately.
cvt (04-27-24)
cvt (04-27-24)
So just an update on this.
i was able to resolve the noise using a silicon lubricant spray on the motor and hinges. I guess the lubricant was really dry so after spraying on the track, motor, and hinges and opening and closing the moonroof a few times the noise disappeared. I shot the videos below so you can hear the difference.
im always very good with regular engine, brake, and tire maintenance but always forget sunroof / moonroof maintenance. live and learn I guess.
moonroof with noise:
moonroof with resolved noise:
The following 2 users liked this post by cvt:
05RollaXRS (10-06-24),
1wacko (10-06-24)
Good to hear you have resolved. Have not heard from you in a long while as you have been MIA for a while.
https://youtu.be/HcBnqQTA0z8?si=BSgl0spk4wr4GQkI
https://youtu.be/qcxRfnMkzQs?si=LmF_ptVc9xYFAHDI
