RC F teaser Brochure
Old 05-12-14, 01:35 PM
4TehNguyen
4TehNguyen's Avatar
they already showed the M3/M4 torque curve and it drops off pretty hard after 5500. Turbo cant make power everywhere have to balance lag and high end power. Another reason I dont like turbos. This new 5.0 should scream. Some reviews of the new M complain that it doesnt sound exciting anymore, it even have speakers to generate sound. This torque curve is good for daily driving but not optimal for the track
Old 05-12-14, 01:47 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,484 Likes on 1,788 Posts
I wonder why it shows 8000 rpm when the M4 engine rev cut off is at 7600 rpm?
At 7500 rpm, the M4 engine is producing only 70% of its peak torque so this engine must be unexciting to rev past 6500 rpm since it is completely out of puff and out for lunch after 6000 rpm. Who would call this a proper high-revving engine?
This is just BMW trying to make it high-revving just for the sake of putting a high redline. It is completely pointless. I don't know why they even bothered to make the engine rev past 6500 rpm since it is plummeting hard after 6500 rpm (loses almost 100 ft-lbs in a matter of 1500 rpm only).
Old 05-12-14, 01:50 PM
4TehNguyen
4TehNguyen's Avatar
max power is still 5500-7500 so thats where you are during tracking. Just have a constant hp value instead of a rising one from 5500-7500.
Old 05-12-14, 01:54 PM
05RollaXRS
05RollaXRS's Avatar
Yeah, but the torque is falling hard. After 6500 rpm, the engine will feel like it is completely out of steam and out for lunch (similar to the F10 M5). The powerband of that engine resides from 4500 - 6500 rpm. After that, it is a complete waste.
High-revving engines are all about producing the maximum amount of torque at the highest revs. It simply goes against the simplest paradigm of a high-revving engine because it isn't.
There were similar complaints by journalists that the BMW 1M is losing steam after 6000 rpm so they questioned why they needed to put a 7000 rpm redline on it?
Old 05-12-14, 02:07 PM
MPLexus301
MPLexus301's Avatar
Numbers are looking very promising so far. I'm very pleased with 470hp
Old 05-12-14, 02:18 PM
05RollaXRS
05RollaXRS's Avatar
471 HP to be exact (470.6 rounded up).
Yamaha is hard at work on tuning the exhaust/engine note of this screamer. I am blown away by how thorough Lexus has been with this car.
Old 05-12-14, 03:19 PM
spwolf
spwolf's Avatar
Originally Posted by natnut
2UR-GSE?
From what I remember from Toyota engine naming convention ie wikipedia,
2=2nd generation
UR= engine series, V8
G=performance head with wide-angle valves as opposed to F=economy head with narrow -angle valves( 2GR-FSE)
SE= gasoline D4 direct injection
Compared to the UR V8 in the LS460 : 1UR-FSE
Strangely enough, the 1st generation IS-F engine is also designated 2UR-GSE but the RC-F and IS-F engine are obviously different in terms of hp,torque and fuel economy. Could there be a printing mistake in this preliminary literature?
i dont think your info is correct on what the numbers mean... 1 number is the engine size.
As to the engine, we know everything about it except for specs... it is new series of engines with atkinson cycle.
Old 05-12-14, 03:25 PM
spwolf
spwolf's Avatar
Originally Posted by eoph
Different countries have different standards. I'm just going by what the ISF is rated at in Japan on the lexus jp website, which is exactly the same.
i am thinking these numbers are not official, as they wont be the same as old IS-F for sure.
Old 05-12-14, 05:16 PM
ISF001
ISF001's Avatar
Wishful Germans inflating performance metrics--par for their course.
Old 05-12-14, 05:53 PM
Nights
Nights's Avatar
I've read a few reviews which basically said there's no need to go over 6000 rpm in the new M3/4, because it's just more noise (artificial) for nil gain.
And to think that 'M' engineer talked about how it's a "racecar/racing" engine.
Old 05-12-14, 06:04 PM
05RollaXRS
05RollaXRS's Avatar
Yeah, that is what I was concluding from the dyno. The meat of the power band is between 4500 rpm and 6500 rpm. Based on how quick the torque curve is plummeting, it is actually wiser to shift at around 6000 - 6400 rpm and fall back to 5000 rpm than to shift at 7000 rpm where these is far less torque. It would actually be slower if the driver shifts at 7000 - 7500 rpm
Old 05-12-14, 06:34 PM
4TehNguyen
4TehNguyen's Avatar
funny, that engineer should say that this power band is designed for daily driving not the track. M3/M4 would be significantly faster with larger turbos to shift the powerband to the right for stronger mid/high end power which is where youll spend your time at the track. They softened the M up like they did for the 3 and 5, which is why it lost to the IS and GS in multiple tests. RCF has a great opportunity to shine when it gets tested.
Well, there are a couple of shortfalls. It might be spectacularly powerful, but the new engine lacks engagement and sounds disappointingly flat at certain points in the rev range. For owners of the fourth-generation M3 Coupe, this will blunt its charm, but only until they discover the gains in driveability and stunning in-gear qualities brought on by its strapping torque. What it lacks in overall excitement, it more than makes up for in everyday driving appeal. Darn right, you want it . . .
Old 05-13-14, 02:00 AM
natnut
natnut's Avatar
So basically the RC-F engine is more of a track engine than the M4's?
Yeah, so much for BMW's engineers' hyperbole.
Old 05-13-14, 06:18 AM
05RollaXRS
05RollaXRS's Avatar
Yeah, "racing torque" is all about maximum torque available up in the topmost rpm (hence, the peak horsepower keeps climbing and comes in close to the rev limiter). For example, Lexus LFA makes its peak horsepower at 8700 rpm (9000 rpm for NE) and even at 9500 rpm, it is still making over 90% of its peak torque.
RC-F fulfills that very nicely. The M4 engine is just a normal turbo engine that makes the major chunk of all its torque in the midrange and completely runs out of steam after 6000 rpm. That is why the "in-gear" (low speed, tall gear) acceleration of M4 would be good and also part-throttle it will feel very peppy in the midrange.
However, BMW marketing was defiant and wanted to really use the mantra of "race bred" so they gave it a completely unnecessary 7600 rpm redline when it should have been no more than 7000 rpm. They wanted to market it as "high-revving" so they made pistons that can handle the engine speed, but not designed to flow well at high rpms for usable power (being a turbo engine).
I hope all magazines shift M4 at 7600 rpm in RC-F comparisons so that the M4 turns in much slower numbers.
Old 05-13-14, 07:18 AM
LexISguy
LexISguy's Avatar
Wow! 477 PS is 471 HP and happening a t 7100 rpm , which means 349 ft-lbs @7100 rpm or 90% of its peak torque maintained till redline
That means, the RC-F has a very long torque curve that keeps surging upwards till the redline. That is awesome
p.s. Did Lexus not say the peak torque would be over 393 ft-lbs?
Nice close to the 480hp speculation everyone was mentioning. Throw in some future JoeZ products for 500bhp.. I will still like to see the final US specs...
Quick Reply: RC F teaser Brochure
