RC F automotive reviews thread
Old 12-09-14, 06:55 AM
  #571
4TehNguyen
4TehNguyen's Avatar
wonder if they got it mixed up with the RC 350 F Sport which has bridgestone potenzas. RCF is suppose to have PSS stock. In the gallery they clearly shows both cars have PSS
http://www.motortrend.com/roadtests/.../photo_28.html
Old 12-09-14, 07:00 AM
  #572
05RollaXRS
05RollaXRS's Avatar
Received 2,501 Likes on 1,800 Posts
That is definitely disappointing that Lexus did not send it with the Michelin Pilot SS tires. They are bar none the best summer performance tires on the market right now this side of racing slick tires.
Originally Posted by redspencer
In regards to the Motor Trend article with the M4 beating the RC-F around the Streets of Willow track by 0.3 seconds, I noticed that on the Motor Trend spec sheet, it lists the Lexus RC-F being equipped with Bridgestone Potenza tires and the BMW M4 with Michelin Pilot Super Sports:
http://www.motortrend.com/roadtests/...son/specs.html
Doesn't the RC-F come standard with Michelin Pilot Super Sports? I'm an advocate that tires play a huge role in regards to lap times (when driver skill level remains constant) so assuming that the Michelin Pilot Super Sports are stickier than the Bridgestone Potenzas that the test RC-F was equipped with for this comparison, it's very likely that the pendulum might have switched and that the RC-F could have been the one to win the Motor Trend lap time comparison that day by 0.3 seconds if it was using Super Sport tires as well.
Just my two cents...
Old 12-09-14, 07:08 AM
  #573
redspencer
OG Member
Forum Moderator
redspencer's Avatar
At first, I thought this was the case based on the picture you provided from the MT gallery but then I checked further back on the old Head to Head video where the 0.3 lap time difference was extracted from and the vehicles used were different than the ones show on this gallery (Blue RC-F and Red M4 were used for the Randy Pobst timed lap instead of the Red RC-F and Gold M4 from the gallery):
Streets of Willow segment starts at the 10:10 mark. I'm not sure if the reference to the Potenzas for the RC-F on the spec sheet is a typo or not...
Old 12-09-14, 07:16 AM
  #574
05RollaXRS
05RollaXRS's Avatar
Originally Posted by SOM3
Please don't include GTR in this conversation, it is in a different class compared to M3 or RCF.
And I wish you luck at the track since you are so confident. I was simply stating that you can't fight physics, yea the brakes might be better but how much abuse can they take?
Your assertion that a 4000 lbs car with brakes as powerful as the RC-F will "tear up the brakes" is comical and the funniest thing I have ever heard. I don't if you are being overly dramatic or you truly believe that..
You are telling others to take physics lessons, but it is really you who needs physics lessons
For one, for your information, Randy Pobst does multiple laps in each cars. It is extremely naive of you to think he just gets in the car and goes for a timed lap right off the bat. He does an outlap, flyer and then a timed lap in order to first get adjusted to the car properly before he does a timed lap. R&T also said they did multiple laps in the RC-F.
He is talking about GTR and has a perfectly valid point. Braking comes down to only tires and brakes. There are tons of other examples of 3900 - 4000 lbs cars that do just fine lap after lap without any brake fade. The IS-F was 3815 lbs and it did just fine with inferior brakes lap after lap.
It is just that you continue to look for excuses to criticize the RC-F.
Old 12-09-14, 07:25 AM
  #575
4TehNguyen
4TehNguyen's Avatar
you said 4000# vehicles tear up the brakes in 2-3 laps. Guess how much the GTR weighs. Apparently there are brakes exist that can stop a 4000# vehicle on the track. GTR brakes arent that much bigger than the RCFs 15.4 vs 15.0 front and 15.0 vs 13.6 rear, both are Brembos. Yes heavier cars work the brakes more but 2-3 laps is sheer exaggeration. Randy probably drove a lot more than 2-3 laps in the RCF and what were the results? .3 sec off from a lighter car with CCB. Didnt seem to have trouble there.
People constantly complain about the weight, but can never explain away the .3 sec difference which is within driver error. M4 shouldve beat this car by 3 seconds considering specs, not .3
Old 12-09-14, 07:54 AM
  #576
Mr Bond
Mr Bond's Avatar
There will be a lot of tests on "real" tracks in the future, I personally dont care a bit for results on the two tracks RC-F were tested at. Both of them are very slow and R&T:s really uneven. Uneven sufaces at lower speeds gives a more soft and heavy car advantages in the same way a Toyota Landcrusier will handle a lot better and be faster than a Lexus NX F sport on a bad country road. Its not always a bad thing to have softer chassis.
Lets se Nurburgring , Silverstone, Monza , Laguna Seca and other tracks where you really torture brakes and suspension.
Old 12-09-14, 08:01 AM
  #577
4TehNguyen
4TehNguyen's Avatar
If I hear Randy Probst mentioned one more time, I'm leaving.
He was faster in the M4 so what exactly is your point?
barely faster and .3 sec on a near 1.5 minute lap is within driver error. Not a decisive victory when looking at specs. If a veteran driver has this much trouble being consistent in the new M imagine a novice driver at an HPDE. M limits can only be exploited by experienced drivers. Evo and R&T both reported this instability at the limit on the M. Smoothness and predictability is how the RCF was able to get within half a second of an M with superior specs. That is the hallmark of NA engines and the learning curve on turbocharged engines.
Old 12-09-14, 08:16 AM
  #578
05RollaXRS
05RollaXRS's Avatar
BMW M4 did a 1:40 around Laguna Seca. About 3 seconds quicker than the E92 M3 M-DCT. Randy will lap with the RC-F around Laguna Seca at the end of 2015.
Old 12-09-14, 01:41 PM
  #579
DFGeneer
DFGeneer's Avatar
I think it's a typo.
Check the still image of the blue RC-F that Randy Pobst used on the track in the video at 17:37.
It clearly shows Michelin tires.
Old 12-09-14, 02:30 PM
  #580
TF109B
TF109B's Avatar
These lap times are useless unless youre the guy setting them. Who goes racing in their m4 or RC F? Tracking is not racing. You might be able to run 90% of Pobst, and a guy in the M4 might be able to run 85%. Its up to the driver and car. He might have a better feel with pushing the m4 than the RC F. No one single driver is going to get 100% from both cars at the same time. Thats why Nurburgring lap times are done with factory drivers.
Old 12-09-14, 07:47 PM
  #581
Ryanmcd
Ryanmcd's Avatar
That's it, I did a lot of road racing and it's the driver when it's this close, also who cares I want something that I can drive and now worry about and not have to tinker with that will last 5-10 years and still start.
If you wanted a track car I say again get a GTR, you can get a 2013/14 for mid 80's. But I got the RCF for my daily because it works for that well.
Old 12-10-14, 04:53 AM
  #582
ISF001
ISF001's Avatar
http://www.motortrend.com/roadtests/..._f_comparison/
A few comments:
1. Carlos conveniently did not mention the 3/10s difference in the 0-60 runs.
2. He does not discuss the near dead heat hot lap. It seems like Randy over braked the RCF on the corners and lost lots of tenths. Watch the hot lap video link.
3. Aesthetic comments about cars are always based on personal preference. To me, the bimmer designs all look alike and blend together. To others, they are stand out cars.
Overall, it's a reasonable article.
Attached Thumbnails RC F automotive reviews thread-2015-bmw-m4-lexus-rc-f-side-profile.jpg
Old 12-10-14, 08:02 AM
  #583
toyotatom
toyotatom's Avatar
The 0-60s were mentioned in the video along the 1/4 mile time, figure 8, G force and braking all won by the M4. The 0-60s and other tests were on the summary page at the end of the article also.
Motor trend has never liked the looks of the RCF, I don't agree with them either, I think the RCF has a modern and very sporty look to it. The M4 looks good also but you can only do so much with a kidney bean grill.
A few comments:
Old 12-10-14, 08:10 AM
  #584
4TehNguyen
4TehNguyen's Avatar
main issue is, people buy these type of vehicles to stand out but the M4 doesnt, looks like a other pedestrian 3/4 series with an M Sport kit. Dunno about other people but buying a car in this segment I want to stand out. The M235 and M6 is what M3/4 shouldve looked like, more aggressive. M3/4 isnt ugly, just boring.
Old 12-10-14, 08:29 AM
  #585
MPLexus301
MPLexus301's Avatar
Having now seen a few RCs in person, including the F, I am sort of shocked that Motor Trend so highly dislikes the exterior.
Maybe there are some awkward elements, such as the wide "hips" on the rear bumper, but in person, the RC has street presence and aggression unlike anything else right now. Not only is it aggressive, but I haven't met a single person who doesn't think the front end with tri-LED headlights isn't one of the best faces short of $100k. Lexus did a great job with this car, but alas, beauty is in the eye of the beholder.
Quick Reply: RC F automotive reviews thread
