Brakes Squeeking
Old 01-04-15, 11:48 AM
YzBat
YzBat's Avatar
Default Brakes Squeeking
Fist post so be gentle. I have had my RC-F since November and two days after having it the brakes have been squeaking. I had thought that It would work its way out just had figured since it was new it had to work its way off of the brake pads. I have 1100 Miles on it now and it is still squeaking. I am taking it in on Monday to have them look at it.
Has any one else had this issue yet and did it work itself out. Or have you guys seen any other problems small like this?
Old 01-04-15, 12:29 PM
waynesreef
waynesreef's Avatar
Mine has the same issue since day one. The car has close to 300 miles on it the break still squeaks. It is kind of embarrassing when the car does it in a crowded parting lot. Mine GS OEM breaks has the same problem until I replaced with aftermarket break pads.
Old 01-04-15, 12:40 PM
gs400jon
gs400jon's Avatar
Brembos will continue to squeak.
Old 01-04-15, 03:05 PM
tsopranoMB
tsopranoMB's Avatar
Yes, ALL Brembo brakes squeek, from Jeep's to Maserati's....
See the Service Manager, they will likely replace the Brake Pads at no charge...
Old 01-04-15, 04:41 PM
ISF001
ISF001's Avatar
If you did not seat in the brake pads, that could also be the problem.
Just ask Lexus to do a free pad replacement. Seat in the new brake pads.
Old 01-04-15, 05:08 PM
RetroGamerJP
RetroGamerJP's Avatar
Mine dust like crazy (as expected) but DO NOT squeak as all ... 750 miles. I'll be changing to Carbotech low dust pads as soon as available.
Old 01-05-15, 12:42 AM
Fehdy
Fehdy's Avatar
Same here, I will drop it at the dealer on Wednesday I will update you as soon it's done.
Old 01-05-15, 08:41 AM
darbs242
darbs242's Avatar
Are the front rotors not the exact same as the isf? It's not like that's a new brembo caliper. I bet carbotech already has pads that work.
Old 01-05-15, 11:10 AM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
Lightbulb
Rotors, Caliper & Pads are larger then current IS F
~ Joe Z
Old 01-05-15, 03:25 PM
RetroGamerJP
Totally new caliper front and rear --- does not match anything Carbotech has in inventory. I'm working with them and have provided them a full set of photos and measurements to confirm.
hopefully they will have something soon.
Old 01-07-15, 04:43 AM
darbs242
darbs242's Avatar
I stand corrected. How could i be so misinformed.
Old 01-07-15, 11:43 PM
Roffles
Roffles's Avatar
A quick fix for squeaky brakes on the IS-F is to simply hose the brake dust off the wheels/disks/calipers. This will probably work for the RC too. I'm surprised this hasn't been mentioned yet.
Old 01-08-15, 07:54 AM
gs400jon
gs400jon's Avatar
Can't hose off my Brembos every 20 miles. Drought conditions in CA
Old 01-09-15, 07:55 AM
MisterSkiz
MisterSkiz's Avatar
Metallic Pads...they are going to squeak.
You bought a high performance car....you get high performance breaking and all the perks that come along with it lol
Old 01-11-15, 04:55 PM
jtsimaras
jtsimaras's Avatar
Brembos are famous for this. Same issue I had on my 09 WRX STI....didn't care as they worked great.
Quick Reply: Brakes Squeeking
