any intake there for the RCF ?
#46
Sponsor
![](https://www.clublexus.com/forums/images/ranks/rank-vendor2.gif)
Titanium has nearly 10 times lower thermal conductivity than aluminum, so it is actually a very good material to use for an intake. So for those of you who like the look, heat soak is definitely not an issue with our titanium intake.
That said, the pipe, whether made from titanium, aluminum, or plastic is an inconsequential contributor to heat soak. Keep in mind, you have a massive aluminum intake manifold sitting on top of your engine, that is running about the same temp as your coolant (200+F) with much more surface area than a 90 degree intake pipe.
If you are that worried about heat soak, take off the pretty OEM engine cover (which is actually heavily insulated from below). Willing to bet you Lexus is not tracking the ISF CCSR or the RCF GT3 with an insulated plastic engine cover
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
#47
I'll be putting my pre-order in for this system.
http://afepower.com/shop/details_new...as&&brandID=78
#48
So, any replacement " elbow" that is a heat deterrent paired and a good drop in ( AFE, TOMS, K&N, Blitz, etc) should do the trick. I've never understood why people hype intake claims since they are so easily manipulated with dyno readouts. I'd take form and function over any marketing claim.
#49
15 hp gain and 17 tq without any dyno graph is a bold claim. Sounds like BS to me. There is an ISF thread that evaluated all the intake for the motor and the best one was the " elbow" and a new filter in the box. AFE while looking cool, is said to make more " intake " sound but once an exhaust is in the picture that sound goes away.. ...
#50
Sponsor
I doesn't look like their claiming 'wheel' hp though. I've seen the elbow setup make anywhere from +5whp to +11whp on the ISF(like you said, dynos vary) so they're claim isn't too far fetched as long as they aren't referring to whp. The system is also supposed to match the manifold color, which should look really good.
I have done back to back dyno testing on our ISF. Multiple runs comparing the AFe drop in filter we had vs. NO FILTER. Completely removing the filter made NO DIFFERENCE.
All dyno results on these cars can easily be manipulated and can easily vary by up to 20hp per run.
The other reason some complete intakes show dyno gains is that they actually alter the airflow characteristics through the Mass Airflow housing, even if they use a stock housing diameter. By leaning out the Air/Fuel ratio, you can get some gains, but your ECU uses a wideband 02 sensor and will correct the AFR's back to the target values, thereby negating any gains after you drive a bit.
__________________
#51
#52
Sponsor
It is about $500, but we have a really nice introductory coupon that really brings that price down much lower... please PM me if you are interested, with "RCF Titanium Intake CL discount coupon" in the title.
thanks,
Rafi
__________________
#54
Sponsor
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/titanium_intake_rcf_fe0fb9afea974db36422ca1ff2d351c637d42565.jpg)
Happy Friday.... we test fitted the intake to an RCF yesterday, we should have the RCF specific silicone couplers by Tuesday next week ready to ship.
Also added some more pics in the RCF vendor forum.
thanks,
Rafi
__________________
#55
Hello guys i'm looking for an intake upgrade and heard about the APEXI suction kit and the LEMS but i also bumped into the Cold Air Intake System Takeda.
http://afepower.com/shop/details_new...0L&&brandID=78
Wanted to know if anyone has any feedback or have installed any one those air intakes ?!
#56
#57
The pursuit of F
#58
#59
The problem with the RC-F is that stupid intake noise Lexus wanted it to make. It sucks air from the hot engine, so NOTHING will make that better. I tried closing that flap all the time, but the opening towards the 'cold' inlet after the air filter is super small, so it chokes the engine a little near redline. So put it back to stock, but what an idiotic move IMO
. At any rate, yeah, the plastic intake is not pretty, but a metal one only makes matters worse in the heat-soak department, so left it alone too.
#60
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/1024x764/dscf0520_91f4286558d1111bd0e8fc8ddc2856db0dfc1a67.jpg)
