RC-F on 20" Rennen Forged
Old 02-09-15, 10:09 AM
  #31
RetroGamerJP
RetroGamerJP's Avatar
Originally Posted by 1SexyLexus
Would you happen to know the spring rates you are using? So typically someone could just get the 14' Coilovers and custom spring rates to accommodate the added weight of the RCF compared to the IS350 I would be concerned with not having a camber plate for the fronts, and I wonder what camber arms would fit for our rears?
You could contact BC to determine what they sprint rates are on their 3IS kit and if you want different, you can order custom spring rates from them to meet your needs.
SPC makes arms for the rear:
PN 74520
http://www.spcalignment.com/index.ph...c&task=details
http://www.maperformance.com/lexus-i...spc-72450.html
Old 02-09-15, 10:47 AM
  #32
Deathrow23
Deathrow23's Avatar
looks great!
on a side note, does anyone else agree, the side profile of the RCF looks like an accord coupe.
Old 02-10-15, 09:43 AM
  #33
juvi22003
juvi22003's Avatar
Originally Posted by RetroGame
Not sure why would I run smaller tires up front?
Also, suspension is not 100% identical, meaning I don't think you could use IS350 lowering springs and I know first hand the GS springs that the RC350 guys use do not work (in the front anyway) .... This has to do with the spring perch on the front strut. However, in the instance of coil overs, they do fit meaning they bolt up properly and since the BC racing are full adjustable for height and dampening, they can be dialed in to work on the RC-F no problem.
Ok got you suspension it was explained like this in the first post or maybe i just read it wrong anyway for the tires your are running 265 on a 9.5 up front i'm sure you could run a 255 or 245 and thats not stretched for rubbing purpose I ran 215 and 225 on 9.5 thats stretched.
Old 02-10-15, 12:02 PM
  #34
RetroGamerJP
Originally Posted by juvi22003
Ok got you suspension it was explained like this in the first post or maybe i just read it wrong anyway for the tires your are running 265 on a 9.5 up front i'm sure you could run a 255 or 245 and that's not stretched for rubbing purpose I ran 215 and 225 on 9.5 thats stretched.
FWIW - the difference of 255 / 265 up front does not eliminate the need to address rubbing issue on the front of the RC-F once lowered. The front fenders, although wide, are deceiving... the way the inner fender lining is shaped there are areas that protrude that need to be addressed the moment you drop it.
If you only go down an inch and your tire setup is not aggressive then maybe not ... you go down 1.5 inches and you will need to trim unless you are running stock wheels / offsets.
I've always taken the approach of get the look/setup that I want and resolve any issues that pop up in doing so. I don't let things like shaving fenders or trimming liners stop me but I understand 100% that there are a lot of folks that do not want to deal with those obstacles. Especially on a brand new car.
Old 02-11-15, 10:25 AM
  #35
gsintensive
gsintensive's Avatar
Hey Retro
Great job! These wheels look amazing on your RC. I personally would raise near half an inch for that clean look but it's superb nonetheless.
You ever think of change the color of the wheel to gunmetal color for a contrast with white exterior?
Old 02-11-15, 09:20 PM
  #36
dorkacho
dorkacho's Avatar
looks great! need more pics asap
Old 03-25-16, 07:35 PM
  #37
jimmymac30
jimmymac30's Avatar
this is sexy! great work!!
tmoore8878
05-04-16 12:31 PM
kayshkim
01-24-15 07:59 PM
Pearl250
03-26-10 06:48 PM
mdgrwl
02-06-10 09:04 AM
Quick Reply: RC-F on 20" Rennen Forged
