Chirping Noise...
So the dealer sent my bad fuel pump back to Japan...only problem is that there isn't another pump in the US. Lexus had not sent this part over yet.
My dealer gets told from Lexus Japan, 'We can get one you in about a month'
After much debate it will arrive next week possibly. The dealer was also told another RCF is waiting in service with a bad fuel pump as well somewhere in the US.
So off I to roam in beautiful jellybean RX.
Wouldn't get too worked up about a noise. Lol, I thought I heard a chirping type noise while in my garage when I first got mine and read this thread. That was 16,000 miles ago and not one hiccup since.
It's not about being "worked up" by any one of us. It's wanting to know why a v8 makes this unusual and unpleasant noise at idle. My question remains. Thx.
About the chirping noise, the reason this car supposedly has 3 pumps is to use the quieter PI one at idle and off-idle rpm. If the DI ones are working at idle, guess the only reason for the PI pump's existence is to avoid carbon build-up by spraying fuel at the ports and cleaning intake valves from oil. And boy, is that needed on this car that gulps oil thru the intake (bad PCV design) when driven aggessively. Will check if my car makes the chirping noise at idle, but probably does. All my other DI cars do, although not as bad as the 2 videos above.
Thanks for sharing your thoughts. I'll gladly take this chirping noise over carbon build up that plagues vw motors that include their Audi rs engines.
It's still annoying but nothing I can't drown out with the mark levinson. I just want to know that it is par for course. If there is a fix I'll take it in to the dealership.
I have a different loud sound. It is a loud humming.
it comes from the area in front of the rear driver side wheel. It is mostly coming from the rear seat behind the driver.
it actually hums for a few seconds after the car is turned off. It was on the rack and the tech said he thought it was the fuel pump. There are no bulletins and Lexus techs were scratching their heads. They made a video audio tape to send to Lexus and gave me the car back.
I will keep everyone updated on what is uncovered.
Recommendation is simply to try different gas and it should correct the issue. It certainly solved mine
skydash
05-16-17 09:06 PM
