Wheel specs?
You might ask RetroGame.
He posted in the following thread
https://www.clublexus.com/forums/rc-...d-on-rc-f.html
15mm (r) 20mm (f)
5x114.3 Bolt Pattern
60.1mm Center Bore
12x1.5 Thread Pitch
15mm (r) 20mm (f)
60.1mm Center Bore
12x1.5 Thread Pitch
Here are the correct offsets..
Originally Posted by Joe Z
Bolt pattern is 5x114.3 or aka 5x4.5
All 3 OEM - BBS wheel designs will get the same wheel & tire specs:
Front 19x9 + 50 offset with a 255/35/19 Michelin PSS Tire
Rear 19x10 +41 offset with a 275/35/19 Michelin PSS Tire
Caliper/Rotor Largest Diameter?
Thanks Joe Z.
Anyone know what the largest diameter of the rotor/caliper is or can take the measurement? Wondering if 18" wheels (would be used as winters) would fit. Thanks!
ModInJapan
CL Vendor Products for 2IS
02-23-18 08:12 AM
