RC F Aftermarket Wheels (Merged Threads)
chromes (03-10-21)
#467
RCF Wheel wisdom needed...
hello all- I love to hear group wisdom here on a potential wheel setup. I have to admit, I am super naive on wheel specs and feeling like I passed the entire derivatives topic in calculus after reading all the posts.. I am good with staggered, in the end Toyota engineers should have done their homework (used to have 08 335xi many years before and though it eats tires for breakfast, it looked good, it handled good situation)
2020 RCF - current everything as stock. At this point no plans of changing suspension or height. only planned upgrade is the exhaust in addition to wheels.
Primary motivations - aesthetics / handling / cornering stability - weight
Wheel in question - Volk TE37 Ultra Track II
Option 1 - most likely:
Sizes - 19x10.5 5x114.3 22mm / 19x9.5 5x114.3 35mm (44mm available)
Tires - PS4s / thinking 275/35 F and 295/30 or 35 back (flexible on tire choice if better recommendation)
Option 2:
Sizes - 20x10.5 5x114.3 25mm (20x10 35mm or 41mm offset available) / 20x9.5 5x114.3 45mm
Tires - PS4s / thinking 275/30 F and 295/30 back
what do you guys think? highly appreciate your views & thanks a bunch!
Option 2:
#469
19" Cruize VTR Gunmetal Grey - Winter wheels
My winter wheel setup
Fronts: Cruize VTR 8.5j X 19 5x114 et32, fitted with 255/35/R19 Vredestein Quatrac Pro's
Rears: Cruize VTr 9.5j X 19 5x114 et35, fitted with 275/35/R19 Vredestein Quatrac Pro's
The actual centre bore of these wheels aren't exact lexus OEM, but the provider (extreme alloy wheels UK) provide spigot rings and wobbly bolts and they fit without issue.
Everything fits well and no rubbing/noises going quickly over bumps. Not tried with a full load. The fronts sit further out than OEM and the rears do a minor amount. Been and serviced at main dealer with no complaints.
Excuse the OEM ride height!!
cvt (09-23-22)
#470
New Wheels! Some Rays Grahm Lights 57 Getters
Fronts: 19x9.5 +25 255/35/19
Rears: 19x10.5 +25 295/35/19
On Swift Lowering Springs, no rubbing that I can tell so far, but have not driven on the freeway yet.
ecstaticSC (02-13-23)
#471
Can you post couple more photos of front wheel from different angles? Based on the above specs you pushed fronts out about 3cm vs stock . Keep us posted with your driving experience.
#472
yok3dIS (11-06-22)
#474
We have Titan7, Volk Racing TE37, and Work ZR10 in stock ready to ship.
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
#476
The following 2 users liked this post by JT2MA71:
RandallNYC (09-23-22),
yok3dIS (11-08-22)
#479
Thank you! Car is on Ohlins TTX suspension and rear is still separate springs and shocks, not true coilovers like most people do. Spring rates are 18K/18K. No rubbing. But, I flattened that front fender liner protrusion where the fender meets the fender side vent. No work needed in the rear.
