RC F Aftermarket Wheels (Merged Threads)
#76
FRONT: 20x9 +20, 255/30-20
REAR: 20x10.5 +25, 285/30-20
Stance Wheels + Toyo Tires
Installed this setup yesterday, Im on RSR springs, the front rubs on deep/big bump at high speeds (if the car falls and bounce) and hard turns on reverse.
#77
If any of you guys want the specs for a properly fitting wheel/tire package for the RCF, let me know. A properly fitting wheel/tire package shouldn't rub at all lowered or not. The package should also allow you to run as wide or wider tires as well. A lot of the specs I'm seeing here are done up by "instagram" wheel companies who aren't custom; rather, one-size-fits-all approach with non-motorsport backgrounds. It's a cheaper route, but you get what you pay for. It also looks like the RCF audience isn't as well versed as the more seasoned M and 911 community. I'm a big Lexus F line-up fan as a former ISF and current RCF owner. Here to help.
#79
Here are the custom specs I ordered. 19x10 48mm offset and 19x12 51 offset. I spent alot of time using shims and spacers to come up with those specs. I will be running 315 30 19 and 255 32 19 cup 2 tires. What do you think?
I've ran 9.5 wide fronts and 11 wide rears on my IS-F with no issues at all. car was lowered too.
#80
Ok nice to know
I was thinking of running 19x9.5 +35 and 19x11 +43 with 265/35 and 295/30. I'm looking for an aggressive but functional setup.
#82
I think I saw you this morning heading towards Brickell Ave, car looks good. I was in a loaner ES350 that I have been driving for a few days, makes me REALLY appreciate the F.
#83
Most probably
Most probably since I live in the area, have only seen a black and white stock one close to me, btw why are you away from your F in a loaner?
#84
I was getting the brake pads changed out, the brake squeal was non-stop and way too loud on my car. Now the car makes zero noise and the wheels have almost no dust on them.
#89
#90
