RCF Screen always starts on GPS Map
Hello
My Canadian RCF with Nav and Mark L. Sound system always starts on the GPS map mode on the screen then I need to press the home button to see the split screen map and radio mode which I manually set . Everytime I start the car it always defaults to just the map and every time I need to press the home bottom near the mouse pad. The dealer could not help me out on this question and after 5 months in the car I am getting tired of pressing the home button to see the radio setting.
Also the brake sequel is driving a little crazy I cannot drive the beast with the windows open, I checked some other threads about the changing the pads is there any solid long term fix from Lexus?
There's a setting you need to change to keep the audio screen on top....I had the same question. I forget what the setting is called and I can't get to my car right now. I'm sure you'll find it.
My brakes screeched for the first couple hundred miles, but it has gone away
If you turn the car off while displaying radio (not home with split screens) it will start at radio instead of gps. I also want it to start at split screens and dealer was no help. Maybe someone here knows.
As far as brakes take the car in to service and they'll provide free brake job, or replace pads etc...
As far as the scren definitely needs more options, mine always starts in split screen and always have to click on map to make it full screen, it's annoying, I want mine to start in full scree map mode all the time.
gotcoffee
ES - 6th Gen (2013-2018)
04-29-16 06:55 AM
