mod to keep 2nd intake always open
Don't know if I like it yet, will try it out for a week and switch back to stock and see what I enjoy more
so I did this Friday.. over 2 days and 230 miles I have experienced a slight drop in MPG, according to the AVG MPG on the NAV I went from 19.3mpg down to 18.6mpg.
I'm going to guess the reason it the increased intake sound has resulted in a heavier right foot.
doesn't bother me, I didn't buy the car for the MPG, just pointing it out...
I just ran across this today for the first time.
Seems like heat soak is negligible considering its 100F here in Dallas anyway.
Also, if it already opens up on its own above a certain RPM, heat soak would still be present then anyway. I'll have to do some further reading before doing this on mine.
I used to have it when I bought the car (previous owner had done it). Yes, there is a noticeable torque loss. There is more growl, but definitely once the dealership put it back on, I never removed the line again. If you want more noise at low rpms, go with a full exhaust. Having a full exhaust fixed the lack of noise issue below 4000 rpm.
Tech Info Resource
IS Fs with this mod went slower at the track consistently.
Ltaboso
IS F (2008-2014)
11-25-15 01:07 AM
