Noise coming from drivers door....
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/240x320/img_1878_47e6ed011580e81a1956df0ddb4e4e39a35a82c4.jpg)
Has anyone experienced any annoying noises coming from this area on your drivers door? If so, did you look into it or your dealer?
Has anyone removed their panel ?
Thanks in advance...
Sorry, should have provided more info. I hear the noise in a typical neighborhood street. Semi-rough. occasional bump.
What it sounds like is the plastic under the door panel hitting the metal door. If I could figure out where the door panel screws are I would pop the panel myself. I found 2 under the door control, I think the rest are those plastic pop in connectors, but I cant be certain.
I wonder if anyone could point me in a direction of a picture of the anchor points.
Dealer took a look and deemed that the door panel had to be taken off and they adjusted the window track. No more noise. Apparently, its the window not forming a tight bond against the seals so over rough pavement it shifts up and down and you hear the noise.
Hopefully, its the same issue and the dealer can fix it.
That's a good thought. So here's what I just did. I shut the door with a thin microfiber cloth in between the window and the seal and performed a road test. No noise! It's funny how it sounded like the door panel. Thanks ! I have a direction to go now. I appreciate your help.
Elfin66
RX - 3rd Gen (2010-2015)
06-07-19 08:21 AM
