Winter Wheel/Tire Setup (Merged Threads)
#91
What did you guys have to do with the TPMS? I purchased a set of the monitors for my second set of wheels, but I was curious if they had to be synced with the system using a specific tool or visiting the dealership. Im hoping neither and they'll automatically sync up, but everything with this car seems to be somewhat cumbersome. Thx
#92
No need to visit the dealership. My tire shop ordered the correct sensors for the car and synced them up when they installed the tires on the car - pressures come up on the multi-information display screen as expected.
#93
Now that I've swapped my winters for summers, my TPMS readings are blank. Talked to the dealership and they say that the sensors need to be programmed every time (for $75) a tire is swapped. Any DIY solutions that don't cost a fortune?
#95
I asked the tire shop to duplicate the winter tire TPMS IDs / codes from the OEM tire sensors. Don't need to "reset" them via OBDII every time I go in for a swap. Hope this helps.
Ne1tHeRe (02-01-18)
#96
Hey all... tis the time again and I'll be driving my car through its first Chicago winter. Any update for those that have been driving the car in snowy weather with a dedicated set of winter wheels/tires? I'll try driving it for a season with a winter setup and if it's bad, I may look for a winter car.
TIA
TIA
#97
I liked my XIce Xi3s last year, and my notes on the fitment of them on my Niche Misanos is on page 6 of this thread. With the stability control etc. this car is just fine on ice & snow. Also picked up the ATEQ TMPS tool - entered the winters manually and scanned the summers from the OBD port with no issues. Haven't done the swap yet but I'm not expecting any issues with updating the OBD.
#99
I ended going with the Biizzak LM-32 with the oem wheels. I have the wheels and tire protection plan so should be ok through this season. I'll look for a more dedicated setup next year. Don't drive much anyways so hopefully this works out.
#100
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1124/img_5006_956534f300b0541678a076fa63e173dabc619919.png)
I was looking at those too! Ended up with the pirelli winter snow tires they had great reviews both snow and dry, with stock rims was recommended by tire rack and dealership
#101
#102
I'll be driving mine all winter. Of course I don't expect to be driving in snow... So all season tires are all I really need (due to the temperature being too cold for summer tires).
I just got my Michelin Pilot Sport A/S 3+ tires installed today. I went with 265/285 instead of the stock 255/275. My first impressions are awesome. I don't know if it's just because I got new tires, if it was the extra width or is it was the alignment. But I like the way it feels a little bit more than I did before I got them put on. I haven't had a chance to really test out the traction yet. But they seem to be gripping a little better than my nearly worn 255/275 PSS.
I also like the way they look on the rims a lot more. The stock sizes look a little narrow for the rims so the rims stick out and are very easy to curb rash. These new tires look like a perfect fit for the rims and I don't think the rims will be easy to curb rash (It still might, so I'll not purposely try).
I have noticed a very slight drop in MPG. I have the same 30 mile commute every day and I don't have traffic. So I can set the cruise control and get consistent readings. They do vary a little due to temperature, but stay within a threshold. So far it appears that I'm getting about 1-1.5 MPG less with the cruise set at 80 MPH (~24.5 when my average is usually around 26). But I'll need more days to get more accurate averages.
These tires are just temporary until my Volks arrive in March. Those will be getting even wider "summer" tires. But I may keep these for the winter and just swap rims when needed.
#104
I also have the dealership installing the winter tires, may be a silly question but when dismounting and mounting they should be pretty careful and not scratch the rims correct? I have the 20 spoke rims I'm a little worried.
#105
I just found a small scuff on the rear of my car that wasn't there before I had my tires done yesterday. It's small enough not to bother me, and it may buff out. But it was still not something I was expecting and I also cannot prove where it actually happened. I had my tires installed at the dealer...
