How do you remove the grill in front of the Transmission and Engine Oil Coolers
Several times it would have been nice just to pull the plastic grills off and clean out the bugs. What are the details on how you can do this?
Using a tube to vacuum tube through the grill holes can result in bending the fins. Attached is an example hack at a coin op on a road trip. Need a better way.
Thanks
Thanks
Received 1,064 Likes
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
Entire front clips needs replacing due to many road debris hits.. Including semi tire chunks
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Joe Z
