APEXi Smart Accel Controller: Weigh-In If Installed (Merged Threads)
#46
Can someone share how they mounted the Apexi button to the one of the blank spots near the blind spot monitor button? Not sure how to remove the panel and where to run the wiring from the pedal to the dash panel. Any pics would be a great help. Thanks in advance for your help!
I'm in the same dilemma... Hopefully someone will see this and jump in to help
#47
Hey Finny, I may install mine this weekend and just leave the button loose on the center shift console until I figure out how to mount it.
At least this way I can start to enjoy the benefits of this and worry about the cosmetic part later.
#48
https://www.clublexus.com/forums/bui...-thread-4.html
#49
#51
I finally installed this and it works as promised. When in sport plus mode and red hi throttle mode. Peeling out is almost hard NOT to do if you tap the gas .it is that sensitive on take off.
Makes even normal mode more responsive as well. Kind of cool with the color lights lit up at night.
I did not mount to the left panel by BSM switch as spent few mins on it and could not figure quick or easy way to take it off. So just Velcro it on right side of the driver dash.
Reaching up under dash to remove the switch was very tight space and bit hard as you cannot see the lever you need to press to release it. Had to use mirror and light to view it first and finally got it off.
Also did not opt to install reverse switch as did not want to splice the wire. Just have to leave it in Eco mode whenever I take it in for service.
#52
DIY for Apexi Smart Accel Controller
Thanks!
#54
#55
#58
It's a cool mod for the price! Customers love them, cool bang for the buck.
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
#59
#60
I am extremely happy with it, completely changes the way the car drives and accelerates. I keep it in red 80% of the time and when I want to cruise a bit more I put it in purple.
