Red Cabernet Leather - Color rubbed off w cleaner
Has anyone cleaned their red leather seats and had some red color transfer to the mf cloth?
I decided to clean my seats with lexol. I sprayed a little onto my mf cloth and rubbed the cleaner on to the seat. Not sure which part of the seat I rubbed but noticed some red on the cloth.
Because it's new that some color comes off?
Happen to anyone?
Thanks.
Happen to anyone?
Thanks.
A little coloration the first time you clean them is perfectly normal. In fact, I always condition new seats right away, to leave that on a rag, rather than on your clothes. But I never spray anything on the seats, especially with perforated leather. Spray it on the cloth, then clean them. Also make sure it's an actual leather cleaner, not vinyl. Always try to use conditioner first. If a stain or something doesn't come off (they usually do), then use a leather cleaner. But cleaners dry the leather, so use a conditioner after that. Also remember best time to condition coated leather is in summer, when it's warm; absorbs better.
It could be residual, but I would be care about the cleaner and conditioners that you use.
Lexol is safe, but try it on an inconspicuous part of the leather first. I have not had any issues with this product.
https://www.groupon.com/deals/gg-lex...FVCQHwodzt8Kgw
Happen to anyone?
Thanks.
Happen to anyone?
Thanks.
[QUOTE=ISF001;9327543]It could be residual, but I would be care about the cleaner and conditioners that you use.
Thanks for the link.
Happen to anyone?
Thanks.
Happen to anyone?
Thanks.
I've cleaned a couple vehicles with cab red nuluxe recently and observed no color transfer. I used a diluted detergent (LM) for cleaning. My first concern would be that area showing color transfer may have been slightly damaged and re-dyed to cover up or repair the damage. Like real leather, faux leather is coated and should not show any color transfer. Is this color transfer happening in one area only? What if someone were to sit in the car with white or light colored clothing? Would not be good.
I'd suggest talking to your dealer and show them where the color is coming off. Demonstrate with the manufacturer's suggested detergent solution and a white cotton towel.
I'd also relate the process I use for cleaning. When in doubt follow the manufacturer's recommendation. It is always a good idea to first do a test spot in an inconspicuous area to be sure the products you are using are not going to cause damage.
1. Vacuum to remove all loose dirt/dust.
2. Using a foam applicator, apply some detergent to the foam and squeeze several times to generate a thick foam. Gently agitate the area to loosen dirt and let the foam dwell for a minute or two but not dry. Wipe up with a white cotton towel. Examine the towel for dirt. If soil is visible on the towel, repeat the process.
3. If towel is not showing dirt, wipe down the area with a clean wrung out towel to remove all traces of the detergent then gently buff dry with another cotton towel.
During the cleaning process, take care to not overly wet the material.
I prefer to use 100% cotton toweling for the interior as it is less abrasive than microfiber. When dry, I recommend applying a fluorocarbon protectant (I use LM Protection Cream).
Do visit the Automotive Care and Detailing forum for more.
You may wish to visit the Automotive Care and Detailing forum for more but here is my experience.
02lexus300
Automotive Care & Detailing
12-15-05 03:54 AM
