RCF Carbon Mirrors
I heard back from the dealer that these were added there and were supposed to be on the invoice for $600 but they forgot about them. He didn't know if they were wrapped or dipped but from the pictures shared I'm pretty sure they are dipped.
Here we go I finally found the real carbon fiber mirror covers I was talking about, and it's from one of the CL vendors too.
http://www.bulletproofautomotive.com...n-door-mirrors
Your #1 Lexus Vendor
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
I've got these mirror covers from a different forum sponsor than either of the ones mentioned here for a very good price. See link to thread below where I've posted pics. Planning to have these installed on the car tomorrow. In just looking at the shells, the left and right look like mirror images of each other so I don't think (hoping) that JDM vs USDM will be an issue. If it was the actual mirror it would probably cause a problem as the mirror (convexity, I think) is different between markets. Will post pics in my build thread once installed. A little nervous about what the install is going to run me. The door panels may need to be removed and then remove the whole mirror assembly to replace the housing. Ouch....
https://www.clublexus.com/forums/bui...ork-s-rcf.html
Well folks, bad news... The JDM/RHD mirror housings don't fit on our cars. Visually they look the same but, our housings are just a tad bigger and so the way the mirror is positioned in the housing causes the RHD ones not to work. Tried to mix and match the upper and lower pieces as an alternative but, it was a no go.
Luis at Carson has been great to deal with during this process, he's covering the shipping back to him, working with the vendor to ensure full refund, and putting together another "option" to help satisfy what I was trying to achieve.
As an FYI, these were the LEMS covers that are listed on other vendors sites.
Former Sponsor
Hey guys, this is Bo from Bulletproof Automotive. I just saw this thread so I thought I'd chime in...
We've recently developed some carbon mirror covers for the RC-F for you guys.
These are high quality wet carbon layup using authentic OEM Lexus cores. We used real carbon fiber and bonded them onto the factory cores.
This isn't the traditional carbon "wrap". These aren't cheap vinyl covers or "snap-on" carbon pieces.
This is literally a part of the mirror housing. We recently made a set for one of our Club Lexus members.
I also started a new thread regarding our RCF carbon mirrors. You can check it out here...
https://www.clublexus.com/forums/clu...ml#post9396995
If you're interested, either email, PM, or call me and I'll be happy to help you. Just ask for Bo.
Bo,
Thanks for posting and for you guys stepping up to make additional products for our community. This looks good and the weave, coloration and pattern appears to match the factory, which is an area that I had concerns about when trying to source this. The LEMS CF matched the factory exactly but, unfortunately didn't fit. I'll send you a PM for pricing and availability as I am curious. One question I'll post here and maybe you can also address it in your new thread as well.
The factory mirror housings come in 3 pieces. It appears as though you have bonded two of the pieces together with the carbon cloth. The bottom section where the hole is comes up and around and forms the bottom border of the turn signal lamp and is black plastic, matching the mirror surround. The upper portion is painted body color and this is the portion that LEMS did in CF. Can you confirm? Hopefully this won't cause any issues when you go to fit them as there won't be any "give".
Former Sponsor
Bo,
As for the mirrors, you're right on the money. We actually spoke to LEMS regarding these mirror covers for the RCF a while back and they notified us that the LEMS mirror covers were only for the Japanese Market cars and wouldn't not work with the US market RCF.
Each of our mirror covers are special made to order parts so they do require a bit of a lead time which can vary. I'd estimate roughly between 3-6 weeks quoting conservatively.
You're correct. There are 3 pieces to the mirror housing. LEMS offers the top back housing cover, which is usually painted body color, in carbon that is bonded to a factory OEM core like we do; however, they don't bond together the bottom piece so that is still left plastic.
We thought it would look better to have the entire back housing done in carbon so we bonded the two pieces together to create one full back housing and then converted the entire piece into carbon fiber. It looks a bit cleaner and a little nicer. Benefit to you guys is you get more carbon
Luckily installation wise, there's enough "give" to where you can mate up the two halves fairly easily and then there are 4 small screws behind the mirror lens that basically tighten everything together.
We've had quite a bit of experience with carbon production. We built an entire brand using the R35 GTR platform where we only produced custom carbon pieces.
Many of you Lexus/RCF guys also own or have owned a GTR most likely know or have heard of our BrandRR/GT-RR brand. We thought it might be cool to bring that same type of experience to the Lexus platform as well.
I have some cool photos below of some of our carbon work for the R35 GTR interior pieces. The car is our own demo car we built a couple years back. Essentially we're applying this same type of process and same production quality to these Lexus parts.
I'll try to answer everybody's PM's by tonight and tomorrow. If you have any questions, feel free to give me a shout!
Former Sponsor
