Paddles not working in second gear in manual mode
Old 02-13-16, 01:02 PM
crazymikie
crazymikie's Avatar
Default Paddles not working in second gear in manual mode
Has anyone else experienced this- I've had it happen on two different cars now.
Driving in normal mode and the transmission in auto. Once the car gets up to temp, (usually at a stop), move the gear selector to manual mode. If you punch it, I have not issues shifting from 1st to 2nd gear, but sometimes, the up shift paddle will need to be hit multiple times in 2nd before the car will shift to 3rd.
It seems to only happen the first time I go from auto mode to manual mode during a drive cycle.
It happens on my car and another car I test drove.
Old 02-13-16, 01:23 PM
FR500GT
FR500GT's Avatar
And the car is not still "cold"?
Old 02-13-16, 03:52 PM
crazymikie
crazymikie's Avatar
Nope. I leave the car in automatic mode until the rev limiter goes up past 7000 and the oil/coolant temps are up as well.
Old 02-13-16, 11:38 PM
GGawaran
GGawaran's Avatar
I run into this issue for the first 5-10 minutes of driving, sometimes it won't let me shift, in D mode, no issues. I am guessing there is a oil temperature it needs to reach before you can shift freely.
I seem to run into this in Sport+ mode where it won't let me shift to 7 until I have driven it for a while.
Old 02-14-16, 06:26 AM
crazymikie
crazymikie's Avatar
If anything, you'd expect the car to want to shift earlier when the oil temp is not optimal. Very weird.
I thought S+ mode only used the first 6 gears. I didn't think it would ever go into 7 or 8.
Interesting...
Old 02-14-16, 02:16 PM
DougHII
DougHII's Avatar
Never drive in normal mode so don't know. Normal mode does tend to annoy me. Too many gears and conservative napping.
Old 02-15-16, 05:51 PM
JCtx
JCtx's Avatar
Only in auto, or high speeds. In manual, it shifts to any gear you want, whenever you want.
But yes, before tranny (not engine) is at full operating temperature, shifting can be b*tchy. Once fully warmed up, it works just fine. And it also shifts much quicker and harder. I always drive in sport mode in manual, since sport+ makes the fake noise I don't like. Shift times are indentical in both modes while in manual, fortunately.
Old 02-16-16, 10:20 PM
da mayor
da mayor's Avatar
I have the same issue when it is cold
Old 02-17-16, 06:26 PM
ISF001
ISF001's Avatar
Until the oil, tranny fluid, and water are up to specific operating temperatures on cold days, you will not be able to use potimally use downshifts, blips, etc. I find it takes around 15 minutes to reach operating temps when it's below 30-degrees F outdoors.
A
Nimo
GS F (2016-present)
03-15-18 05:22 AM
juncho
11-28-16 02:32 PM
gdcheng
NX - 1st Gen (2015-2021)
05-13-15 07:13 PM
spotxc
03-30-14 02:17 PM
Quick Reply: Paddles not working in second gear in manual mode
