I accidentally found another way to display the above features in the round tach / speedo monitor that I never knew about nor recall it being in the owners manual. This makes it more entertaining now to see these displays in same spot as tach and speedo. Now you can use the display box on the left side to show something else like radio station, compass, etc.
I heart the RCF instrumentation. Whatever vendor they chose for those milky metallic dark gray rings, they should be applauded and that subtle non-lit tiny F badge on the analog speedo - class.
You access this by going into the TVD distribution screen or g force screen in the F submenu. Then press the middle button on the right side of the steering wheel. It will give you a slightly different readout on the tach section as shown in the OP
Press the return button to resume normal display function
