Rear Wing Removal
Rear Wing Removal
Has anyone removed the rear wing before? I'm thinking about getting it wrapped and would like to do the entire thing.
Do you just pull the trunk liner and unbolt it?
Can't you do the wrap with the wing in the up position by manually pressing the active wing control button to the left on the bottom dash area?
OR Youcan remove the wing like you wanted in your post, I guess. There was a post a while ago here about the TSB DOCUMENT on the active wing getting stuck. I can't find it right now. I had printed it out to give to my Lexus dealer to get my stuck active wing in the up position fixed under warranty.
You could probably wrap it while in the up position, but getting things right underneath would be a pain.
If it's a real pain to remove, i may go that route.
just pull trunk liner and unbolt the wing...just two bolts...it take more time to pull the trunk liner off than to unbolt the wing
lexi4darin
08-27-06 03:54 PM
