RCF Splash Guards or Mud Flaps?
Old 03-12-16 | 06:28 PM
ba2sy's Avatar
ba2sy
Default RCF Splash Guards or Mud Flaps?
Hi! is there any splash guards we can install on the RCF? From my latest canyon drive after a rain, my car was the most affected one compared to C63, Porsche, M4/M5, Z06 and it's not good.
Old 03-12-16 | 09:40 PM
equalme's Avatar
equalme
Nothing you can really do except get some PPF in that area.
Old 03-13-16 | 04:01 AM
Ne1tHeRe's Avatar
Ne1tHeRe
This.
Mudflaps/splash guards are going to cause a lot more drag and mess up the carefully calculated areo design of the car.
IMHO, paint protection should be the very first mod done on this car.
Old 03-13-16 | 07:28 AM
rjmalm's Avatar
rjmalm
Since you dont have PPF now you may already have some deep scars in the paint depending on how coarse the mud might have been. Make sure you get them corrected before putting on the PPF. After I got some scars, I had PPF put on the rocker panel but did not do the rear fender (rocket level) but wish I had. You can see my green annotation in one of the attached that shows the ppf edge.
After I had the car detailed (paint correction) and PPF added to the rocker panels, I decided to buy
Rally Armor Universal Basic Mud Flaps Part #: MF12-BAS-BLK. You can only put these on the front since there are no existing bolts for the rear.
I only put them on when I am on road trips where there might be gravel or mud. There are 2 bolts on each side and a plastic push pin that you can replace with a bolt. Rotate the Flap 90 degrees to be able reach the inside bolt. I created a paper template to transfer the hole locations from the car to the mud flaps.
I used washers to create a better (flatter) mating surface between the flap and the Lexus plastic cover in the fender well. You might consider a bevel washer on the other side of each next to the bolt head. I put a little glue each of the bolts just so the bolts dont come out with road vibration. This is especially true of the bolt that is used in the push pin hole since it does not really tighten as much as I would like. When my muddy trip is over I just just take them off. They only look crappy for a few seconds until you remember the mud and scars that can get on the car. This solution does protect my paint for a road trip and then they can be removed. If you already have white/gray scars in the paint, try some Dr ColorChip that is color matchesd to your Infared, and have the rocker corrected by a detailer to remove all scratches and then add the PPF. I found 1 picture that I took on a trip and attached it so you can see how they look from the front view.
Attached Thumbnails RCF Splash Guards or Mud Flaps?-rally-ar-pr.jpg   RCF Splash Guards or Mud Flaps?-dsc_3298.jpg   RCF Splash Guards or Mud Flaps?-dsc_3297.jpg   RCF Splash Guards or Mud Flaps?-rocker-panel-scars-before-ppf.jpg   RCF Splash Guards or Mud Flaps?-trip-to-ca-from-az.jpg
Old 03-14-16 | 04:15 PM
alfaromeo3's Avatar
alfaromeo3
I won't put one at all.
Shorty79
Florida Lexus Club
11-23-16 10:56 AM
Foob
09-23-13 01:03 AM
modthispny
03-10-13 08:06 PM
silverceli
01-31-08 03:42 PM
GSE25
Automotive Care & Detailing
57
05-02-06 07:34 PM
