Lexus rcf wheel fitment :)
Hello guys.
I just got my rcf and I installed my advan rsii 19x9 and 10 offset 35 all around. I am using the stock tires for now.
I will be dropping the car with swift springs .
So I was wondering if I could fit a 255-35 and 285-35 in the rear after drop![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Here is a pic of the Lexus
![Name: 8C729467-08A4-427C-B358-00A0CD2064AE_zpsakcxie5p.jpg
Size: 218.9 KB](https://www.clublexus.com/forums/attachments/rc-f-2015-present/442857d1501524700-lexus-rcf-wheel-fitment-8c729467-08a4-427c-b358-00a0cd2064ae_zpsakcxie5p.jpg)
Thanks in advance !
Thanks in advance !
UFOHunter (09-25-23)
Theoretically, you should be fine b/c you are not too far off from the stock offsets, the front wheel and tire size is the same as stock...the rear you are only going from 275 to 285. The thing is that not every tire is identical so one at 285/35/19 can be slightly wider/narrower than another 285/35/19.
If I had to bet, I would say you are good.
Also, not sure if it is just the picture but I would get your rear camber checked out when you get the alignment done after installing the new springs.
I think I will be okay too.
Here is another pic
Thanks for your help
![Name: CE12412F-7ACD-4D39-A518-E53C1B21BE42_zpsyhhelji4.png
Size: 525.2 KB](https://www.clublexus.com/forums/attachments/rc-f-2015-present/442846d1501524680-lexus-rcf-wheel-fitment-ce12412f-7acd-4d39-a518-e53c1b21be42_zpsyhhelji4.png)
SFBLUEISF
IS F (2008-2014)
07-15-10 08:11 PM
