Factory Alignment
What are you all finding when it comes to the factory alignment? I think I was reading where the ISF were set from the mfg so the toe was pointed out a bit, purely for performance reasons but will also cause uneven wear on your tires.
I would rather have mine wear evenly and sacrifice any performance decrease because of that and trying to figure out if I should pay to have the alignment performed on my new RCF.
wheel alignment within first 12month / 20,000 miles is free at dealer.
https://secure.drivers.lexus.com/lex...ce/warranty.do
Basic Warranty
The Basic Warranty coverage is for 48 months or 50,000 miles, whichever occurs first.
Wheel alignment and balancing are covered for 12 months or 20,000 miles, whichever occurs first.
Basic Warranty
Is what I'm reading true or will I be wasting my time as the MFG isn't doing the alignment that way? I haven't thought about the dealer but would think they would try to give me push back as they wouldn't want to do anything unless I have uneven wear which is too late then...
all I can say is talk to your dealer,
I told the service adviser mine is a street/commuter car and will not be on a track and to please align it as such.
@ 7,000 miles and I am not noticing any abnormal wear.
you can pull the factory alignment specs off the Toyota TIS website,
https://techinfo.toyota.com
you will need to pay$15 for 48 hour access, and you can pull off whatever service info you need.
Not sure what the factory spec. range is but normal toe setting would be slight toe-in or just set to 0 toe upfront. Slight toe in on the rear. I wouldn't run toe-out on the street or with a pure-DD vehicle.
