Rcf with axle issue w/video
I leased a 2015 rcf in late October. Since then I have a total of 8900 miles on the car . The car has been in for service a total of 13 times . The major problem was a clicking sound from the driver side axle under hard acceleration from a stop light or on downshifting when coming to a stop. They replaced the axle at 5900 miles . 2500 miles later the clicking sound started again this time on both sides . The car was brought to the dealer where the mechanic waited for a master tech from Lexus to look at the car . The tech stated it's ' normal ' for a loud clicking sounds to come from the axles . Please help ! Has anyone else had the same issue ?? https://youtu.be/SNo5cwhTK0g
Sounds like something suspension related, could be the little metal tabs that hold the rear brake sensor wires. I wore through these wires after lowering my car, just needed to bend the clip a little with some pliers to stop it rubbing when the suspension is under load. Worth a try
It's difficult to diagnose problems via internet.
I would try another dealer if I was certain something was wrong with my vehicle and a dealer said it was normal. If it was discovered at another dealer that something was actually wrong then I would never visit the first dealer ever again and I would leave a bad review for them online.
Are sure it is not suspension related. Seems like it kicks in when it squats. I have heard many cv joints and axle sounds over the years. Definitely not a cv click and do not hear typical axle grind. There is definitely a noise, but I would be curious if more made the same sound. I never listen for nor would hear something like that. Lol, I didn't realize I could see my license plate in the back up camera either until reading a thread about it . . .
Can you actually hear that from inside the car while driving? Is this a different sound than the axle made before it was replaced? Sorry to hear of your frustrations.
unfortunately I can't find another one and my dealer doesn't have one . Lexus has refused to provide one
Where in NY are you? I'm on long island. I've had my car for about a year with 13.5k miles on the clock and I haven't had any issues and I most definitely do not have that noise.
I'm in Scarsdale NY and I wouldnt have a problem driving to you but I was told that Lexus Usa says it's normal and as far as there concerned I don't have a case
I got my car from Rallye (near my work), you may have better luck at another dealership. I suggest you open a case (basically complain that this needs further investigation since even with the initial fix it's clearly not resolved if the noise remains) with Lexus corporate and call a service adviser at Rallye and give them the case #, explain the situation that you've already went to xyz dealer and they said this, and provide the youtube video before you waste your valuable time going around.
If not, I have a friend with a tuning shop near my house who can throw it up on the lift and may be able to help as well. More than happy to bring my car by as a comparison to help you with your case.
Heree is a quick video I made with my cell phone just now you can here the axle on the driver side click, sometimes it's more then one click sometimes it's one
