Get Your RCF ECU Flashed!
#76
Hummm...... I'm not sure about the engine braking and NOT rev matching when in AUTO Sports+. Meaning if I'm cruising along at 75mph and I hit the brakes "normally " and not stand on the brakes, I remembered the RCF engine DOES REV MATCH as it downshifts automatically in AUTO .
So what you are saying is that the RCF engie ONLY DOES REV MATCHING if in MANUAL (NOT AUTO) NORMAL, SPORTS, AND SPORTS + MODES? If this is true, then I'm learning new things about thd RCF every time. 😊☺😀😁
If that is true then every time you let off of your gas you are wearing your engine then. That's all engine braking is. I'm not talking about dropping it to 2nd gear at 80 mph and watching the tach bounce off of the limiter.
In any case, the engine and transmission are surely getting more wear from the hard acceleration I do almost every time I accelerate. But I'm sure the car will last until at least 100k miles, even after I boost it. Beyond that I don't care because I'll not likely be the owner anymore.
I've been engine braking since I started driving and I've not ever had anything fail because of it. I'm not saying that it can't happen. I'm saying that I've not ever had it happen.
Edit: I forgot to add that Lexus already has engine braking programmed into the RC F. Every time I use the brakes the transmission automatically downshifts and it doesn't rev match... at least in Sport+ mode, which is all that I use.
#77
I also do not drive in auto, except when using cruise control. I switch to manual mode as soon as I leave cruise control. So I don't know how it behaves in auto mode. Once again, it is not relevant to the discussion. The discussion was about engine braking and damage to the transmission/engine.
#79
Relevant or not, inquirING minds want to know!!!
Can't wait to get back to my RCF aND try iT aND see.
Flowrider said engine braking was bad for your powertrain. I said Lexus programmed the RC F to use engine braking in Sport+ mode. I have no idea about rev matching while cruising... that was not relevant to the discussion. But I do know that it does not rev match while downshifting and you are trying to stop the car. That could be potentially dangerous to apply throttle to a car while trying to stop...
#80
But, over the life of the car would you spend more total money on brakes and rotors vs. having to repair the powertrain if using engine braking? That's an unknown. Especially since I've not ever had any powertrain failure with any of my vehicles for any reason. If the powertrain finally fails at say 200k miles, is it because of normal wear and tear or because of engine braking?
I'm speaking rhetorically. I don't expect a response because it's pretty much impossible to give a factual answer. Some vehicles can be babied and fail at 10k miles while others can be abused and still be going strong at 100k miles.
However, I will say that if Lexus is purposely using engine braking, and they normally engineer their vehicles to last 200k+ miles, that the powertrain can probably handle engine braking. The powertrain can handle 467 HP being fed through it, so why can't it handle a fraction of that force in the opposite direction?
#81
Yes, over the life of the vehicle more money will be spent on brakes and rotors. I'm beginning to find out with this on my LX570 with PCS where it brakes first to slow down instead of down shift and use engine braking .
Semi trucks use engine braking all the time. So are the vehicles with the traditional manual stick shift. All seemed to survived engine braking with no problems. Maybe these vehicles are built differently? More hardy and real tuff? IDK.
These days with all the electronics on board vehicles, it does not take much to have something go wrong without warnings.
But one thing for sure, the RCF drive train components are made to last much longer, say compared to anything KIA OR HYUNDIA makes. I know it is not apples to apples comparison. All I'm saying is a reputable car maker like Lexus tested its vehicles extensively before releasing to the market unlike some of the other makers take it to thecextreme by making calculated risk assessments versus how much profit to gain before discovery by the public. I know Lexus may do this also, maybe just on a lesser degree?
I think we should just drive the RFC like the Lexus engineers designed and envisioned and not keep worrying about it.
Fair enough. You are also correct in stating that it is a lot more costly to repair the powertrain than to change the brakes and rotors in a single change/repair.
#82
But make no mistake, I'm not worried about it. In fact, I intend to push more power out of my car than probably anyone else on this forum. If nothing in the drivetrain breaks in the process, I will be amazed! Of course, I will follow my tuner's advice and replace anything they recommend beforehand.
#83
X2 .
For those who don't want to do the reflash bc it ain't broke.............well, I don't know if Lexus will still cover it AFTER warranty is expired? Also in the meantime...........as already said, enjoy the lag.
What about the fact that if the folks who did not go for the reflash get a malfunction fuel pump down the road (especially after warranty expiration) and Lexus refuses to cover the fuel pump, especially Lexus had announced a fix for the fuel pump?
The only items that I think one would lose is the time taken to go the Lexus dealer and the 2-3 mpg decrease after the ECU reflash. But these are very small price paid for a much smoother running RCF. After all, we all did get the most powerful CURRENTLY in production Lexus OUT HERE. So why not enjoy the RCF to the fullest extent possible with minimum expense?
Mine didn't have the noise, but the lag was present for sure. I'm a VERY good customer at my dealer and pay cash for my cars....maybe they treat me differently. I called him up and explained the TSB after seeing it posted here on our forum. I told him I didn't have a noise but read where others didn't either but they also noticed the lag was gone and better performance from the vehicle. He basically said since it's a TSB for all 2015 & 2016 RCF's and the GSF they would do it. I don't see how a dealership could refuse to do it for some of you. I'd demand it. For those that say don't fix it unless it's broke......well enjoy your lag. I think most of you who are regulars on here know I'm not a Bs'er..... I'm telling you guys the lag is COMPLETELY gone. I've given you the info, do with it what you please.
shadow1118 (12-26-16)
#84
X2 .
#85
Just had mine done and all I can say is WOW what a difference. Lexus of San Diego in Clairmont Mesa did mine.
#87
Gents - the reflash does NOTHING for the transmission. They remove the battery cable as part of the reflash, so you get a "back to initial settings" reset when they do the reflash. If you think your gearbox is acting up, just disconnect the battery for a minute (60 seconds), and try again. Nothing in the fuel pump reflash changes the TCU software.
bugjug
SC- 1st Gen (1992-2000)
02-15-11 04:41 PM
