RS*R x FIGS Suspension Installation
Gents (and ladies if you're out there),
I've scheduled to have the RS*R coilovers, FIGS LCA bushings and rear upper links installed this weekend. This is my first "F" car so I'm interested in hearing how some of you with similar setups tuned your suspension (e.g. Fr/Rr ride height, damper adjustments, rear upper links adjustments, etc.). Mind you, I don't track my car but I like to have fun in the crests and canyons here in SoCal. I still plan to stick with the stock wheels until I get FULL use of the OEM tires. Then I'll move on to a 20" wheel (which will require a different tune all together).
Also, any golden alignment numbers?
Any USEFUL (
) insight is appreciated!
Any USEFUL (
I have the same set up but with the Penske coil overs. The Figs bits are great! My alignment went smooth after the install with zero issues. I went with the Lexus specs( any decent alignment center should have the proper specs). The bushings install is super simple as are the control arms. Stick with the factory specs and you should get great tire wear.
https://www.clublexus.com/forums/bui...-tsm-uilt.html
TOPENDMS
Suspension and Brakes
09-24-18 08:48 PM
