Twin turbo start up
Old 12-20-16, 06:39 PM
yellow2112
yellow2112's Avatar
Originally Posted by Phinatic
If this is a stock motor, what a waste. Even with just 4psi on a single SC, the effective compressive ratio would be around 15.6:1 at sea level, a grenade waiting to happen on pump gas, IMO. Your going to be very limited on the amount of boost and timing you can run, so you've got all this pent up potential you can do nothing with. Sure, you can run water/meth injection, back off on cam/iginition timing, improved intercooler, etc, but again, not enough mitigative actions to turn it up. On a stock motor, my money would go with nitrous.
Yeah, its videos like this that just give tuning a bad name really - since no one has any clue (that I can see) what has been done to that engine.
To the novice, it looks like two (very expensive) HKS products, some piping and clearly there has to be an intercooler somewhere up front but in order for massive detonation to be avoided and melted pistons/con rods, you'd probably have to spend $20 grand on rebuilding the engines entire upper end, cams, cam gears, valve train, port/polish and then reinforce the entire lower, pistons, rods, maybe the crank and that's just the block...what about fuel, pressure gauge, wastegate(s) etc, etc, etc. The two chargers alone would cost over $10 grand knowing HKS.
I has a heavily modified MR2 for several years and the only reason I knew it needed forged rods? A million nimrods had gone before me and blown up their engines to find out what the weakest point was.
Perhaps this is the end result:
Old 12-20-16, 07:56 PM
skipetenj
skipetenj's Avatar
From the video the exhaust is behind the front wheels also sounds like fairly radical cams, Definitely highly modified.
Old 12-21-16, 12:29 AM
BigRick82
BigRick82's Avatar
LOL that's a promod. That's my buddy Josh "Squatch" Ledford in the red hat. He's the tuner for Ekanoo Racing. He flies to Bahrain frequently as he works for the Ekanoo's personal race team/shop of around 80 cars? Josh is part owner of Late Model Racecraft here in Houston.
TxPride
Performance
08-21-19 11:50 AM
sramos25
Performance
26
01-10-17 05:16 PM
ArmyGrl88
Performance
04-08-14 06:33 AM
calboy76
IS - 1st Gen (2001-2005)
07-26-10 09:05 AM
morris
Performance
23
04-15-05 02:36 PM
Quick Reply: Twin turbo start up
