Did my best time on the dragway
12.747@113.43
1.808 60'
stock michelins with 9989 miles, with light burnout
90F outside according to my car's temp
borla cat-back
only thing i did different from the first run (12.8 my normal time like the past) is using sport mode not sport plus.
1.808 60'
borla cat-back
LRCSALES (03-02-17)
for some reason I felt sport+ was bouncing off the limiter and couldn't time it right.. sounds weird I know
Then I ran twice with sport mode just for a change, both time I got 12.7, where as I did at least 10 total passes prior with sport+ and only achieved 12.8 and trapped lower
also the 1.8 60' was with sport mode. Can't wait to put on 305/30 and see how I do
That's surprising that you had a 1.8 60' and still only ran 12.7.
I recently had a 2.08 60' and still ran a 12.69 at 114mph in my ISF. Temps for me were closer to 60 degrees, but I imagine that if I ran a 1.8 I would have been around 12.2 in the 1/4!
How did you launch that hard? That is an awesome 60' time.
90 degrees is pretty hot. If you calculate the ET based on the density altitude I'll bet it's a 12.5 or better.
1.8 is a great 60' though. Did you rev-launch it or just gas it from idle?
I'm going back home for 2 weeks beginning this Friday. I may try to hit the local strip. But I'm not bone stock anymore...
I'm not a fan of bench racing, but it's good for getting ball park numbers.
I had full traction control off and used manual mode for shifting.
I haven't been back since.
