need assistance with code P0420
My car has little over 5000 miles, recently installed the apexi midpipe (no resonators) and now getting CEL with P0420 code. There are no leaks i can tell, and I doubt the CAT is bad. Is it possible that the downstream O2 sensor went bad? Already check and wires are not twisted.
And... just for me to be clear, is bank 1 @ the right side (passenger side)?
thanks for any assistance.
does that midpipe delete the cats? that code is usually associated with cat deletes without use of defouler/o2 sim.
if not, just clear the code and see if it comes back.
luislopezt (01-13-17)
Cats were not deleted. Car has less than 6k miles. I clear the cel but it return after 100 miles or so. I think the second o2 may have been damaged. I just need to know if that can cause the cel.
Thanks for your reply
Yeap, damaged oxy sensor can cause a P0420 code.
Since work was done in the mid pipe section, I think one of these are possible:
Damaged or faulty rear oxygen sensor(s)
Damaged oxygen sensor wiring, bad oxygen sensor connection
Leak in mid pipe exhaust, bad gasket or improper flange mating.
mre2000
02-03-13 06:21 PM
sepukku
07-14-12 04:45 PM
