Front pads AND rotors need replacement at 23K mile??
Old 04-17-17 | 09:52 AM
  #31
mjeds's Avatar
mjeds
Originally Posted by jhalb
i just took my car in bc it was squeaking. got it end of yr 2015 and it had 13,000 miles on it. they r telling me i need to pay $1250 to replace front brakesand rotors add tx and shop supplies. is that normal?? seems absurdly quick to need new brakes i dont think i even drive aggressively
There is an LSB for the squeaking, as long ad the pads are not below 6mm thickness and you are still under the 4/50K warranty, the LSB should cover the replacement, mine was done at my 10K service.
post #19 in this thread has the LSB number:
https://www.clublexus.com/forums/rc-...em-pads-2.html
here is the LSB in PDF:
https://www.google.com/url?sa=t&rct=...52479541,d.eWE
your dealer should follow that if your complaint is the squeal and excessive dust.
Old 04-17-17 | 10:09 AM
  #32
jhalb's Avatar
jhalb
Default Help
"The technician recommends the following
Front brakes and rotors
$1249.97 add tx and shop supplies. Please let me know to proceed with additional repairs." Thanks for ur response above im gonna see what that does for me but is he just telling me rotors to just make me spend money?
Old 04-17-17 | 10:52 AM
  #33
mjeds's Avatar
mjeds
I'm @ 21K and only had the above TSB done for the pads, so yeah I would say they are pumping your for money.
unless the rotors are warped, or as previously posted measured below their minimum thickness, there is no reason to replace them.
did they provide you with the measurements? My dealer did at my 20K service, full measurements of the pads and rotors in writing.
Old 04-17-17 | 11:08 AM
  #34
4TehNguyen's Avatar
4TehNguyen
more BS from the dealer, you dont have to get new rotors when you get new pads. I highly doubt youre below rotor min thickness at this mileage.
Old 04-17-17 | 11:53 AM
  #35
lobuxracer's Avatar
lobuxracer
Tech Info Resource
+1. This seems to be the most common scam service advisers use to pump up their sales numbers. Ask for the measurements - have them show it do you in the shop - then use the specs in my previous post. From that you can extrapolate what service life you have left.
I can only think of one way you would wear through pads and rotors in less than 15k miles, and you would need to have one foot on the brake, pressing down, the whole time you are driving the car. I seriously doubt you are doing that. If you are, you might reconsider how you are using the brakes.
Old 04-17-17 | 04:08 PM
  #36
Davew77's Avatar
Davew77
Or if a caliper is sticking. I'm at 36k miles on my factory pads and rotors and still have 6-7mm left on the pads and no sign of rotor damage. Although I do realize that this is not the norm for our cars. My miles are almost exclusively highway miles and I don't have stop and go traffic in the sticks.
If they told me that I needed new rotors at 13k miles I'd inform them that it's a warranty issue and see how they want to proceed at that point. There is absolutely no reason why any car should need new rotors at 13k miles unless something in the brake system is malfunctioning. (Unless you are tracking the car and using non-factory pads)
Old 04-17-17 | 06:56 PM
  #37
lexusrus's Avatar
lexusrus
That's pretty good.
I'll keep this in mind when the time comes for me to change my brakes.
Has anyone ordered these specific rotors and pads from this company? Did it all fit and work?
Originally Posted by mjeds
rockauto has Stoptech Slotted Centric Rotors for the RCF for $86-$120 (rear/front)
http://www.rockauto.com/en/catalog/lexus,2015,rc+f,5.0l+v8,3310304,brake+&+wheel+hub,rotor,1896
and Stoptech Centric pads for $38-$56 per axel, be advised the rears require a separate purchase of the "wear sensor wire" as it is not built into the pad:
http://www.rockauto.com/en/catalog/lexus,2015,rc+f,5.0l+v8,3310304,brake+&+wheel+hub,brake+pad,1684
rear wear sensor wire:
http://www.rockauto.com/en/catalog/lexus,2015,rc+f,5.0l+v8,3310304,brake+&+wheel+hub,brake+pad+wear+sensor,10283
so ~$400 in rotors and ~$200 in pads, and 2 hours of your time to do it yourself, or $3000 at the dealer.. your choice.
Old 04-18-17 | 07:18 AM
  #38
Bayernfan's Avatar
Bayernfan
Did they happen to mention how thick the pads are when new? At 4mm you are at 45% available wear remaining before you reach minimum thickness. Distance from the backing plate to the lip isn't a big deal at all. What is a big deal that isn't mentioned here is how thick are the rotors? I have heard many dealership horror stories telling owners they "only" had 4mm of pad left, but without knowing what the original thickness was, that number is meaningless. Same with rotors. They like to throw an absolute number at you thinking you know nothing about the brakes, and end up selling you rotors that still had 50% of their service life left. The tech sells them on eBay (yes, I have bought OEM rotors this way) and they are perfectly good - I used them at the track!
FWIW - RC F numbers:
Front brake pads Standard Thickness: 9.75 mm (0.384 in.)
Minimum Thickness: 1.0 mm (0.0394 in.)
Front rotors Standard Thickness: 34.0 mm (1.339 in.)
Minimum Thickness: 31.0 mm (1.220 in.)
Rear brake pads Standard Thickness: 11.68 mm (0.460 in.)
Rear rotors Standard Thickness: 28.0 mm (1.102 in.)
Minimum Thickness: 26.0 mm (1.024 in.)
Finally, there is no reason the rotors can't be machined, but why would you want to? All you are doing is removing the metal that is there to absorb heat. I never machine rotors, and I've never seen a rotor turned on a brake lathe that I would run on my car. The factory uses a centerless grinder to surface the rotors, and the same centerless method will resurface them with an identical finish to what the factory provided. The hard part is finding someone who will do this, but IMHO it is the only way to fully restore braking performance if you insist on cutting your rotors.
Thanks for the data. I knew the SA was full of s***. I asked for the thickness of the rotors when I handed over the keys to the SA. Never got that number, and I have no problem changing rotors(if they need it) with the pads since I do that with my AMG.
I figured that the techs probably sell stuff, thats why I always ask for all my parts that are replaced on my cars. One, to see if they really did replace it and two, so I can sell it if possible since I bought it in the first place!
Since the Brembos are easy to replace, I am definitely gonna do it myself and I think I am done with this dealer (even though they didn't charge me for the 25K service). I take my AMG to an indy shop so I think the RCF is headed there as well. Again, thanks and thanks to others who have posted links to replacement pads and rotors.
Old 04-18-17 | 07:54 AM
  #39
mjeds's Avatar
mjeds
I do the same, ask for the parts, but I also take it a step further if possible and mark them with my initials in sharpie, just be sure. techs can bring me any parts from any car so I want to know they are my parts.
Old 04-18-17 | 07:55 AM
  #40
mjeds's Avatar
mjeds
Originally Posted by lexusrus
That's pretty good.
I've used stop tech on other vehicles in the past and never had an issue with fitment. if/when I do order the parts I'll post up, though I am not due for at least another 20K
Old 04-18-17 | 06:38 PM
  #41
lexusrus's Avatar
lexusrus
Thanks. Good to know there is a friend in the business.
Old 04-18-17 | 06:56 PM
  #42
flowrider's Avatar
flowrider
Concerning StopTech, you may want to read this post posted by site sponsor SpeedFreaks:
Originally Posted by SpeedFreaksUSA
Given the options you listed I'm guessing this is Naz, right? If so I'll echo what we discussed on the phone to potentially help out anyone reading this thread who is in the same boat. Your case specifically is more difficult than most because the track you plan on attending is Road America and that track is *brutal* on brakes. There are multiple braking zones from well over 100mph every lap and that simply will never qualify as "light" track use even if you are in a beginner group. You want a pad that makes no noise, dusts as little as possible, works on a track and is cheap (don't we all ). Unfortunately Mike was on the right track with the old saying "low dust, low noise, track worthy performance... pick two". However with the addition of the Project Mu HC+800 and Endless MX72 I argue that has since changed to "track worthy performance, great street manners, inexpensive... pick two"
Basically here's how it breaks down:
1) Since you are very sensitive to dust and noise on the street the best option is to buy a nice low dusting street pad for the street and a track pad for the track. Best of both worlds with no drawbacks other than the time and labor (or money) to swap pads in and out for track events. We have quite a few guys doing this with HC+800 and NS400 as well as Carbtoech 1521 and XP12.
2) If swapping pads just isn't an option the Endless MX72 is the only pad compound that possesses the versatility you desire... but the cost of admission is a big turnoff to most.
Every other pad on that list is much more of a compromise. You will either have a pad that works well on the street but melts at the track or a pad that is compromised more on both ends of the spectrum (i.e. attempts to be a jack of all trades but dusts more than other street pads on the street and doesn't have the track capabilities that you would hope for).
I don't have high hopes for any of the true street pads on that list making it through an entire session without overheating, fading and wearing very quickly. But I think the Stoptech sports or the Porterfield R4-S have the best chance. I feel like I need to make it clear that although the stoptechs are very inexpensive and have a decently high temperature rating, they have a low initial bite and only moderate midrange torque. They work but they are not likely to "wow" you with the way they go about their business. Also note that they aren't particularly low dusting and consistently quiet on the street. I noticed you commented that they are possibly a cheaper substitute to the HC+800 but I need to drive the point home that they are not even in the same league as the HC+800... the differences across the performance board are staggering if you were to back to back them yourself. To put it bluntly the stoptechs will feel like a slightly watered down OE pad but with a better heat tolerance whereas the HC+800 feel much more like a purpose built sprint race compound. The Porterfields are more expensive but have a slightly lower temperature range but have a little better initial bite and are quiet and much lower dusting on the street. Project Mu NS400 will for sure struggle to make it though on a track like RA and HAWK HPS would undoubtedly give up in the first large braking zone they saw and send you into a tire wall (seriously, those pads have no business doing anything more aggressive than driving to get groceries). Winmax's supply chain is not the best and I can't even get a set of W2 for you for 5 weeks minimum so those are automatically out unless RR or someone else has them in stock for you. Even still I question their touted trackability but they are cheap so not arguing they aren't worth a shot down the road.
Matt M.
Lou
Old 04-19-17 | 08:26 AM
  #43
mjeds's Avatar
mjeds
Lou
all well and good for those moving between track and street, pretty sure everyone in this thread is concerned with street and daily driving.. but good info, thank you.
Personally I prefer carbotech or hawk, but hawk doesn't make pads for the RCF and I can't find full sets of carbotech anywhere, Front pads from some site, rear pads from another and Rotors from two others, for whatever reason no one stocks all the parts front and rear for the RCF, and it is annoying as hell to me to have to buy maintenance parts from multiple vendors.
Old 04-19-17 | 08:38 AM
  #44
Deanrcf's Avatar
Deanrcf
I've had good success running Hawks HPS on my G35. A good alternative to stock Brembos with the same stopping power when warmed up and less brake dust.
Old 04-19-17 | 09:15 AM
  #45
lobuxracer's Avatar
lobuxracer
Tech Info Resource
I had Hawk HPS on my Supra. After putting Project Mu HC+800 on my IS F, I threw them in the trash and replaced them with Project Mu HC+. Dramatically less pedal effort for the same stopping effort.
Quick Reply: Front pads AND rotors need replacement at 23K mile??
