Nitrous for RCF
Old 03-09-17, 12:54 PM
  #31
ssmoked
ssmoked's Avatar
Is the kick noticeable?
Old 03-10-17, 12:19 PM
  #32
SmurFPwr
SmurFPwr's Avatar
Originally Posted by kitabel
Check your State inspection laws: some don't allow "fuel" (you can't discuss this with them, they're not chemists) in the trunk. Others require the bottle to be secured in a specific way.
Most kits are pre-jetted rich for safety, and will produce more than rated power if leaned out slightly (like 5%).
NEVER use it under 3,000 RPM.
It will severely beat up an automatic transmission, since (unlike factory turbo AT) it doesn't turn down the power via spark retard during the shift. You can add this feature with some expensive controllers (MSD) but remember this is a PB on your factory ECM.
This is absolutely the most power for the money, but yes it will destroy the engine if you make a mistake ("what happens if I increase the jet size?")
you don't always have to keep it spraying straight through on an auto. With my electronic controller I have it turn off 200rpm before my shift point
Old 04-16-21, 02:07 PM
  #33
JTNguyen02
JTNguyen02's Avatar
Could you tell me the nitrous/fuel jetting you used for the 115 shot?
Old 04-16-21, 02:10 PM
  #34
JTNguyen02
JTNguyen02's Avatar
Originally Posted by LRCSALES
after dyno tuning my RCF (just monitoring afr's) here are the results. The runs were completed on a DYNO DYNAMICS which is the lowest WHP dyno in the business but they are good for tuning because like other dynos that have a different type of roller. GOOGLE it if you are confused (i forgot how to explain it. but here goes.
Mods: JOE Z Exhaust, K & N filter, Homemade intake, Deleted the crankcase breathers, heat wrapped air box.
357.2 whp Dyno dynamics read out
425 whp Dyno jet
401 whp Mustang Dyno
Same mods With 50 shot of nitrous from Nitrous Express kit
389.6 whp Dyno Dynamics read out
463 whp Dyno Jet
437 whp Mustang dyno
Same mods with 100 shot of nitrous from Nitrous Express kit (didnt have the right fuel jet for this shot afr was very rich)
461.7 whp Dyno Dynamics read out
550 whp Dyno Jet
519 whp Mustang Dyno
Same mods with 115 shot of nitrous Nitrous Express kit (kept same fuel jet as above)
494.8 whp Dyno Dynamics read out
589 whp Dyno Jet
556 whp Mustang dyno
The shop i visited would multiply 1.15 to their number for an industry average which my final number would
read 572 whp. So in all i gained 140 whp difference on only a 115 shot nitrous which leave me a little perplexed but. the AFR is happy and i managed to beat up on a newer GSXR i assume was a 600c. on the highway with a 2nd gear roll and 3 gear roll after 2 gears he could not pass me i kept a car length lead on him and if you know anything about bikes their upper gears are usual weaker and i would have pulled an even larger gap. I need to run some cars now, to compare my car to the two Nitrous RCFs in Florida.
Could you tell me the jetting combinations you used for the various shots?
Old 04-18-21, 06:41 PM
  #35
finny76
finny76's Avatar
could you tell me...could you tell me...could you tell me...could you tell me...
I8ABMR
IS F (2008-2014)
07-06-16 12:24 AM
TISF
IS F (2008-2014)
11-06-15 05:28 PM
SilverBull
Performance
05-17-07 08:27 PM
Quick Reply: Nitrous for RCF
