Oil Type question
Old 02-14-17, 04:54 PM
woodranch
woodranch's Avatar
Default Oil Type question
Sorry for the silly question ,but I am not next to my manual to get this answer. I am on the road and would like to buy some extra oil for my soon to be road trip. Can someone be kind enough to tell my the exact oil most dealers are using on our cars or what Lexus suggests. Type and weight would be truly appreciated! Thanks in advance!
Old 02-14-17, 05:10 PM
ROK
ROK's Avatar
Try looking under your hood
Old 02-14-17, 05:18 PM
woodranch
woodranch's Avatar
Thank you, had no idea.
Old 02-14-17, 06:35 PM
lexusrus
lexusrus's Avatar
5w30
The manual calls for "REGULAR" OIL. But I used (at 15k miles mark with all prior two oil changes at 5k and 10k done at Lexus dealer at no charge and they used REGULAR oil) 5W-30 SYNTHETIC, Mobile One Extended Performance on my self done oil change at 15k miles.
You can buy the above synthetic Mobile oil at Walmart for like $27 a big 5 quart jug. You will need two big jugs. Total will need like 9.8 quarts depending if you are able to completely drain it. Or just buy a quality brand REGULAR oil much cheaper. But I always used synthetic. Some may find this debatable, but it is what it is.
It is pretty easy once you get the car up. Please observe safety and use jack stands (In addition I placed concrete blocks under the car just in case the jack stands fail. I also put a tire choke thing behind the real tires in case the car rolled.). Make sure you are on on flat level surface as inside your garage. Most residential driveways leading up to inside the garage are at a slight incline for water drainage. So be careful if you do it yourself n the driveway.
Toyota OEM Filter from Amazon for about half the price.
You will need a special oil wrench. My cheap AMAZON broke after 3 years of use on my other Lexus vehicles. I went to AutoZone and bought one on emergency basis. There were two kinds at AutoZone. I got the more expensive one at around $19, if I remember correctly. It's sure not the best quality, but I had no choice at the time as my old one from Amazon broke.
Old 02-14-17, 07:40 PM
flowrider
flowrider's Avatar
Received 1,897 Likes on 1,338 Posts
^^^^Ramps are far easier.
For a filter wrench, Pick one:
https://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=toyota+oil+filter+wrench
For a filter see this thread:
https://www.clublexus.com/forums/rc-...rt-number.html
I use the one ending in YZZA4.
Lou
Old 02-14-17, 09:43 PM
lexusrus
lexusrus's Avatar
Good point. True, ramps are faster. But the ramps I had used for my MB vehicles are "too high" for the RCF front bumper. I couldn't use the ramps without damaging the front bumper on the RCF. I guess I will need new ramps or improvise with some wooden boards to "stack" the approach higher on the tires to get on the ramps without touching the front bumper.
This is the oil filter that I use. See pic below.
Lou
Old 02-14-17, 10:28 PM
flowrider
flowrider's Avatar
^^^^I use Race Ramps. Work Great:
Amazon Amazon
Lou
Old 02-15-17, 05:52 AM
lexusrus
lexusrus's Avatar
$362 for a pair of ramps? I'll keep my old ones or use my jack (only two pumps and I'm up for jack stands) or improvise with my wooden loading boards.
https://www.amazon.com/Race-Ramps-RR.../dp/B003ZAHTC4
Lou
Old 02-17-17, 11:31 PM
cosmo1
cosmo1's Avatar
Motul 5-30...
Old 02-18-17, 05:09 AM
Carnevino
Carnevino's Avatar
Originally Posted by cosmo1
Motul 5-30...
Motul 100%
woodranch
RC F (2015-present)
380
10-08-23 02:59 PM
funcrusher
12
11-19-10 02:39 PM
IceSC
Performance & Maintenance
06-02-09 12:31 PM
SClean4
05-28-09 03:01 PM
wjimmy
06-23-07 12:05 PM
Quick Reply: Oil Type question
