Waze/Bluetooth Question..
Old 02-17-17, 10:01 AM
woodranch
woodranch's Avatar
Default Waze/Bluetooth Question..
I don't have this issue with other cars but when I use Waze thru Bluetooth on my recently purchased RC F, it seems the first part of the directions are cut off and then you hear the rest of it perfectly. I tried to re-boot bluetooth on my phone with the car, but that did not help. Anyone else have that issue and any thoughts or remedies to fix this problem. Thank you..
Old 02-17-17, 10:13 AM
mjeds
mjeds's Avatar
I don't have the issue on my RCF if I am listening to music through the Bluetooth.
if you are not streaming through the Bluetooth and using another source the system has to flip over to Bluetooth when Waze starts the prompt so it makes sense there would be a delay.
Old 02-22-17, 04:49 PM
asinow
asinow's Avatar
I use Waze all the time with no problem. I'll stream XM and Waze simultaneously with no delay. Check your settings: Search, settings, sound and voice, sound output, "device default" should be checked
Old 02-22-17, 04:53 PM
woodranch
woodranch's Avatar
Will do right now and Thank You. Another Newbie question is that when I have Bluetooth music streaming and Waze directions come thru, I can barely hear it. Is there a way to turn up Waze's volume over Bluetooth? Thank you!
Old 02-22-17, 05:04 PM
woodranch
woodranch's Avatar
Hi asinow, where do you go to search,settings and etc...I can not find that on my menu as you described to follow those directions. Thanks again!
mjeds
mjeds's Avatar
waze has it's own volume settings in the app separate from the phone volume.
Old 02-22-17, 05:13 PM
asinow
asinow's Avatar
Sorry I was not clear
Start Waze, lower left on Waze touch the search button, follow my instructions. Waze also has its own volume level output too
Hope this helps
Kenny
Old 02-22-17, 09:13 PM
woodranch
woodranch's Avatar
Thanks you all!
Old 02-24-17, 01:07 PM
dojoman
dojoman's Avatar
You can actually turn off "Play as Bluetooth phone call" in Waze Sound output setting. You will get Waze directions from your phone's speakers instead of bluetooth phone dial, that was causing the sound cutoff in the beginning part.
Old 02-24-17, 04:38 PM
woodranch
woodranch's Avatar
dojoman, Thank you...that is what I will do.
nhawk
10-03-16 09:24 AM
Yaff
03-13-12 09:57 AM
NCGS350
01-11-12 03:26 PM
Money9111
01-31-06 11:43 PM
mab
10-24-05 07:50 PM
Quick Reply: Waze/Bluetooth Question..
