RCF rear seat removal
Old 03-11-17, 06:52 PM
GetKinetic
GetKinetic's Avatar
No Im looking to open up to the trunk, the pass through, maybe permanently. A picture of the upper part of the seat will help me decide what to do about the finish.
Old 03-11-17, 07:29 PM
Davew77
Davew77's Avatar
The reason why the RC F seats do not have the option to fold down like the other RC models is because of additional structural bracing behind the seats. So I am curious what a pass through will look like. I would not remove the structural bracing...
ISFPOWER (03-11-17)
Old 03-12-17, 07:41 AM
GetKinetic
GetKinetic's Avatar
rhat sounds reasonable. Still I want the see if the seatbbut notnthen the structural bracing is removable and what it looks like
Old 03-12-17, 12:17 PM
ISFPOWER
ISFPOWER's Avatar
ill take some pics of the bracing later. i have everything in my trunk out . it was a lot work if you are meticulous and don't want to break anything. not sure if that black metal bracing is removable.
Old 06-08-17, 09:42 PM
GetKinetic
GetKinetic's Avatar
Old 03-10-21, 08:48 AM
nigel821
nigel821's Avatar
Great thread. Will be very useful when I tint the windows... I was dreading the rear windshield but now with the seats out, it shouldn't be too bad at all.
-Nigel
Old 07-27-21, 11:50 AM
nigel821
nigel821's Avatar
I just removed my rear seat. Super easy. The white clips are almost like a one time use according to the parts description from Lexus/Toyota... and of course both of mine broke...lol
Good news is they are $0.69.
Part number: 7269312080
In case anyone needed them as well.
-Nigel
konichiwa3 (07-27-21)
Old 07-27-21, 12:08 PM
konichiwa3
konichiwa3's Avatar
Thanks for sharing that! I will probably have to order some of those as I do plan on popping my rear seat cushion off. Are the clips for the bottom cushion or the upright?
Old 07-27-21, 03:19 PM
nigel821
nigel821's Avatar
The white clips are for the bottom seat cushion. They're actually identical to our 2007 Toyota Solara bottom seat cushion clips lol.
The rear cushion uses black ones and is a much better design why they didn't do the same design for the white ones I don't know?
Bottom white bracket.
Top rear backrest clip
Nigel
Old 07-27-21, 06:38 PM
Yri
Yri's Avatar
Just saying... but it would be nice if somebody weighed the rear seats including the back of them... y'know just saying...
Old 07-27-21, 06:54 PM
nigel821
nigel821's Avatar
Arrow
I'll do it tomorrow after work. they aren't super heavy at all. I honestly wish we got the split fold down seats in the RCF. Would have been better than the silly pass through.
-Nigel
Old 07-27-21, 07:07 PM
05RollaXRS
05RollaXRS's Avatar
Received 2,477 Likes on 1,782 Posts
You can see the 10-point chassis brace there for rigidity in that picture. That is why we don't have folding seats.
Old 07-27-21, 07:35 PM
Yri
Yri's Avatar
A great piece of evidence as to why these cars are as heavy as they are. Also since the rear seats are made of fairly lightweight material I supposed they wouldn't weigh much anyway, but hey its weight reduction bro!
Old 07-27-21, 08:36 PM
05RollaXRS
05RollaXRS's Avatar
Yep. One of the many things. There are rigidity beams running along the door as well. The sills have added reinforcements for longitudinal rigidity and gussets along the firewall for added torsional rigidity of the front end.
Old 08-04-21, 12:14 PM
nigel821
nigel821's Avatar
Arrow
So I am not happy with how I tinted my rear windshield. There ar a few blemishings and a few specs of dust that I should have been more thorough with that I can't live with...smh. (i didn't foget to weigh them either, I'll be doing that shortly.)
Removed the rear seats again. (Buying the white clips again since they of course broke). How do you remove the side pieces? I see there is a bolt at the bottom but how do they ocme off?
Please see picture. Does anyone also know how to remove the rear decklid/ rear pillar pieces. I want to remove as much as possible to make it as clean as possible.
EDIT:
You remove the plastic trim piece that the seat belt fabric goes through... just simply pop it out. Then there is a bolt behind that and there is a lower bolt. Once you remove both of those bolts then the trim piece comes right off. Very easy to do. Makes taking the side trim pieces by the headliner off a lot easier. Just be careful with the trim piece as I've been told they can get scuffed/marked easily if you aren't careful popping them off. I had no issues and no marks. Just use a plastic pry tool from the 12-16 piece kit that are on amazon. Very easy to do.
-Nigel
ehaze
07-09-19 05:35 PM
ejthomp
12-23-13 11:01 AM
Lemleymf
GX - 1st Gen (2003-2009)
09-25-12 09:58 AM
JaytdotP
07-24-10 10:56 AM
Rro
06-15-05 03:51 AM
Quick Reply: RCF rear seat removal
