Yes, Interior Fuse box. Just need to know the location and how to access (in case its not in an easy accessible area).
so the interior fuse box is right under driver side steering column. just peak your head under there and you will see it. has a white lid with blue diagram on it. it uses the low profile ATM type mini fuses. use a fuse tap but make sure you learn or know how to place fuses in it. there are a few guides on youtube. you don't put two of the same amp fuses in the fuse tap which is a common mistake people do.
here is what i actually bought to do my dash cam and power magic box in my rc-f.
Two questions:
1. Which fuse did you tap it into in the RCF Fusebox
2. What Fuse do I need to use for the Radar Dector (5 / 7.5 / 10?)
YES i know that options, however i want to install via the Fuse box as the "HardTap Radar Detector HardWire Kit" has a mute button which is quite handy
