Redline at startup??
Old 03-09-17, 09:43 AM
RCF100
RCF100's Avatar
Default Redline at startup??
Quick question, why is it that when you start the car (talking cold start mostly) your redline is far lower than the normal 7200-7300 rpm? It seems like it progressively raises after some time driving/warming up.
Old 03-09-17, 09:48 AM
mjeds
mjeds's Avatar
because the computer doesn't want you to tax the motor until the oil is warmed up.
going WOT on a cold motor is very bad for the motor. so you are limited to 6,000 rpm until the oil reaches operating temperature.
Old 03-09-17, 09:49 AM
RCF100
RCF100's Avatar
I was hoping it was something useful/intelligent like this, thanks! My only guess was something about engine temp but wasn't positive.
Old 03-09-17, 12:01 PM
Ne1tHeRe
Ne1tHeRe's Avatar
Very smart and awesome feature for better longevity/reliability. Kudos to Lexus engineers!
Old 03-09-17, 01:17 PM
Davew77
Davew77's Avatar
I have regularly seen it as low as 2.5k-3k rpm when I first started the car this winter. The redline is gradually raised as the temperature increases until it's back to 7.3k. The transmission will also automatically upshift when the rpm hits the new redline if you are in manual mode (until the redline is back to normal, then it will no longer upshift by itself in manual mode).
RCF100 (03-09-17)
Old 03-09-17, 01:47 PM
mjeds
mjeds's Avatar
interesting, so it seems to depend on outside temps some how. mine has never been below 6,000 but I live in SoCal so it's never very cold here.
Old 03-09-17, 01:48 PM
RCF100
RCF100's Avatar
I believe I have seen mine lower than 6k, I'm in New York sadly....lol
Old 03-09-17, 02:03 PM
Deanrcf
Deanrcf's Avatar
socal here too and never seen it start below 6k even after weeks of no use. It seems the ECU is smarter than we give it credit
Old 03-09-17, 02:15 PM
paulwall4
paulwall4's Avatar
It also depends if its in a garage or not
Mine is in a open garage and so mine on cold mornings/ nights I've seen it as low as 4k
Old 03-09-17, 02:41 PM
Davew77
Davew77's Avatar
Yeah, I'm contracting in NC. There have been several times I stayed at work until 4 am, But I'm always here until at least 11:30 pm. It has been in the 20's several times and even in the single digits once or twice. My car sits outside at work. It's garaged back at the apartment.
I start the car with Enform most of the time. But when it just sits there at idle it doesn't get fully warmed up in 10 minutes on cold days.
I just interviewed with Lockheed in Orlando on Wednesday for a new contract. I should know something by Monday. So hopefully I'll be back in sunny Florida soon. I'm tired of this cold weather.
Old 03-09-17, 04:29 PM
JT2MA71
JT2MA71's Avatar
Received 1,593 Likes on 696 Posts
Yes, very smart feature by Lexus. I actually programmed my standalone ecu on the supra to limit boost and rpm when oil and water weren't up to normal operating temps. And a secondary speed limit switch for when I let someone else drive it
Old 03-10-17, 07:23 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,075 Likes on 2,469 Posts
..I start the car with Enform most of the time. But when it just sits there at idle it doesn't get fully warmed up in 10 minutes on cold days.
Even in Atlanta it takes 25 minutes of street driving to get the oil to normal temp in the winter. 9.5 quarts needs a lot of heat to get to 180F. At the track, it only takes a lap to get it above normal street temperature on the IS F. Not sure about the RC and GS cars because they have an additional thermostatically controlled air/oil cooler the IS does not have.
Old 03-10-17, 10:33 AM
mjeds
mjeds's Avatar
put the RC-F in sport+ and manual and the oil is up to temp within 2 miles.
Old 03-10-17, 11:31 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
When it's 20 degrees outside? That would require something very special. Coolant isn't even up to temp in 2 miles. I automatically put the GS F in sport mode when I start it. I've never seen it warm any more quickly than normal.
Old 03-10-17, 11:49 AM
mjeds
mjeds's Avatar
oh well you didn't specific the temp.. I live in SoCal, I only see 20° if I go to the mountains. seldom lower than 45° around here.
Quick Reply: Redline at startup??
