Radio switches to navigation.
When you start the car the enform system defaults to nav. I push the radio button to bring up radio, stays for 3-4 minutes and switches back to nav. Took off the negative battery terminal for 30 minutes. Still has the same issue. While shopping I ran into a buddy that has a high end auto repair shop. He said disconnect the negative and then disconnect the positive hold together for 15 min. being sure not to let them touch the terminals. Anyone having this issue???2014 lexus ESPN 350
there is a setting, I believe it is in the General Settings called "Auto Screen Change" set it to OFF.
OFF - Last Screen used remains active
ON- return to Navigation screen after timeout.
When you shut down the vehicle, if you are on the Home Screen it will default back to the Navigation Screen on the next startup, doesn't matter what the above setting is, if you are on any Audio Source Screen then that screen will reappear when you restart the car.
If you keep the Auto Screen Change set to ON, it will always go back to the map after 4 minutes, regardless of what other screen you are on. Set it to OFF.
mjeds (04-24-17)
