Manifolds comparison between ISF and RCF
Old 04-30-17 | 10:48 PM
LegendaryQ's Avatar
LegendaryQ
Originally Posted by Manh3
^^^ what negatives are you experiencing if you don't mind sharing so others won't make the same mistake. Thanks
Fumes, Check Engine light, high increase in fuel consumption...
Old 05-01-17 | 09:54 AM
flowrider's Avatar
flowrider
1: If you have fumes, you must have an 3rd party exhaust that eliminated your secondary cats. Is that correct? Some cars get gasoline smell with cat removal, some don't. Note, I have PPE headers with PPE exhaust and hi-flow cats built into my exhaust system (ISF).
2, The CEL is harder to remove from the RCF than the ISF. But both PPE & RRRacing have solutions.
3. Fuel consumption should not be an issue, unless your putting your foot in it. However, with the CEL, your driving in "Limp Mode". You will be starting off in second and performance will be reduced.
Lou
Old 05-01-17 | 12:01 PM
LegendaryQ's Avatar
LegendaryQ
Lou
1. i have a JoeZ catbackand the fumes increased noticeably after gutting the cats.
2. i agree.
3. Im using the same mode (sport +) and the driving style didnt change... however the fuel consumption has increased noticeably its like the car is consuming 1.25 times more than usual.
Stingraygt
01-25-18 10:13 PM
SikkyMFG
CL Vendor Products for IS-F
50
11-29-17 05:02 PM
rselby
IS F (2008-2014)
13
02-05-16 12:15 AM
PhiDeltBee
IS F (2008-2014)
93
02-22-14 02:02 AM
Akebono
IS F (2008-2014)
02-19-12 09:52 PM
